Question about HP LaserJet 4 plus Printer
Printer is not printing
My printer HP 4M is not printing, after giving command of printing to the Printer the for printing and is showing 51 ERROR on its display and paper comes out with few black patch lines.
  • 138 Answers
The error is a loss of laser beam detect error. Your problem is the laser scanner has burned out. The replacement is easy to accomplish. You simply have to remove the full top cover (3 screws and 1 clip near front right corner). You'll need to remove the side cover first. Once the covers are removed, look for a large black box (about 4" x 6") held in place by 4 screws. The part is available from Dale at Seattle Platen, 1-800-221-2388. Ask for a refurbished on exchange.
Hope that helps you.
Posted on Aug 28, 2008
When giving a print command there is an error message 79.04 showing power-off
you need make firmware Update download firmware from HP.com 79.04 generic error for firmware
Mar 13, 2015 | HP DesignJet 500ps (42 in.) InkJet Printer
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
URGENT-- engine test problem in HP LaserJet 5000n
iam using hp5000n laser printer. It is giving 13.1 &13.3 error messages freequently. (This is paper jaming problem)
May 23, 2008 | HP LaserJet 5000n Printer
System error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click the Advanced tab
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Apr 04, 2008 | HP DeskJet 3320 InkJet Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Hp printer does not print out when command is issued
not specific enough, is the error on the pc or the printer?
in any case here is the manual check here for connections and trouble shooting.
http://www.retrevo.com/s/hp+6210+manual
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
Aug 30, 2007 | HP LaserJet 4p Printer
HP LaserJet 4 plus Printer Logo
110 people viewed this question
Ben Johnson
