Question about RCA CC-432 Camcorder
My camcorder doesn't work
My camcorder won't turn on and/or the function buttons won't work.
    Scholar:
  • 54 Answers
Try re-flashing the official 2.15.00.07.28 radio, that did the trick for my hd camcorder.
Posted on Mar 28, 2012
How do you check the fuse in a RCA 72x Digital camcorder
Posted on Sep 11, 2008
    Master:
  • 473 Answers
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 You need to reset your camcorder. Follow these steps: * Remove the power source. * After one minute, gently press the RESET button with a nonmetallic pointed item until you feel a "click." This resets the camcorder to the factory settings and erases the date, time, and custom settings. * Wait for at least one minute after resetting the camcorder to attach a power supply.
Posted on Sep 06, 2005
Camcorder sony hdr-ax2000e turns itself off
hello, does it show any error code before is shuting down?
May 28, 2013 | Sony HDR Video Cameras
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
Camera won,t turn on or take a charge
If there is a firmware solution on Insignis-Products, you might be able to restore the camcorder to life that way.
However, if the unit won't turn on at all...even when a USB AC charger is used where it should function normally and completely...there is a problem with the camcorder and it may be bricked.
I hope this helps and I hope your camcorder isn't bricked.
Jul 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
RCA CC-432 Camcorder Logo
319 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
