Question about Hoover Refrigerators
I have a Hoover Contour fridge/freezer HE513TF that started tripping the circut breaker last week. I was told the problem could be related to the defrost heater, so I disconnected it while leaving the thermostat still connected. The motor worked for a couple of hours and then stopped but didn't trip the RCD this time. Concluding that the heater was the problem I orederd a replacemnet which I have not received yet. While waiting for the part, I have noticed something that confuses/bothers me: With the heater disconnected all the time, when I leave the thermostat connected, the defrost timer stops the compressor when it clicks (or the dial gets to 12 o'clock)and does not move anymore. I then have to advance it mannually to get it going again. The timer then operates normally but does the same thing again when it has completed a whole revolution which takes a few hours. When I disconnect the thermostat, however, the timer dial stops turning altogether and therefore never cuts out the power to the compressor. Is this normal? Does the timer need both the heater and the thermostat to be present in the circuit to work properly or I have a faulty timer as well? Do you have a schematic diagram for this fridge? Your help will be much appreciated.
I believe you have to push the door light switch for fan to work i dont know if that helps you
Posted on Mar 24, 2009
    Genius:
  • 2,920 Answers
You have to have bith parts in place for the timer to operate correctly
Posted on Aug 27, 2008
Main residual circuit breaker trips fridge approximately every 12 hours
normal fridge takes 7- 12 amps to start, if after 12 hours it trips i would lean towards a compressor issue. once it heats up the comp. may draw alot of amps causing it to trip. is it the only item on that circut? does it still trip being alone on the circut?
Apr 06, 2014 | Admiral 26 cu. ft. Side-By-Side...
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
Jan 31, 2010 | Refrigerators
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
378 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
