Question about Casio Cassiopeia EM-500 Pocket PC
Cassiopia EM500 sync issue
Hi, I have a Casio EM500 and am having problems with initially getting a partnership started with my laptop. There is no connection or sync between my laptop and the Casio unit using a cradle. I am using Active Sync v.3.5 (3.1 didn't connect) and Windows 2000 on the laptop. I understand that an earlier build of 3.5 exists that works better on connection problems. Any help on this or any other suggestions regarding connection would be appreciated. Thanks, cecmd
    Master:
  • 551 Answers
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Posted on Sep 06, 2005
I need htc touch viva driver
Drivers are included with the microsoft software you use to sync eg.
Windows Mobile Device Centre. WMDC.
Or
Microsoft active sync.
You can get 32 bit version of WMDC ...HERE... 64 bit ...HERE...
and Microsoft Active Sync 4.5 ...HERE...
Although Microsoft seem to be having issues with the connection of HTC's to their software and their help department doesn't appear to be much help.
If you already have the software installed. Try uninstalling and downloading fresh copies and re-install.
Also make sure you clear your partnerships in your phone as HTC only allow 2 sync partnerships.
Jul 17, 2010 | HTC Touch Cellular Phone
Removing/restoring partnership
acc to me, partnership once deleted due to hard reset on ur smartphone will not be created under the same name until u delete the same partnership from active sync on pc. To delete the partnership open active sync>file>delete partnership..then create new with the same name with ur smartphone.
hope this will help
Sep 19, 2005 | HP iPAQ HX4700 Pocket PC
NO file transfers are working!
Try deleting the partnership in ActiveSync on the PC, and then create a new partnership. I saw this problem, when I connected the first time to a PC. I tried connecting to a second PC, and had no problem. When I went back to the first, it required that I create a new partnership, and no problem with the connection.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Sync doesn't sync with Calendar, then Hot Sync crashes
Try Creating a New profile from Start Control Panle > Mails > show profile > Add profile > After Adding the profile set the new profile as default
Try deleting the partnership by disconnecting the device and opening and deleting the partnership.
Plug your device back and try to sync
This should work
Sep 11, 2005 | Palm Treo 650 Handheld
Help IrDA WOES!!
Check the PC connection setting on your EM-500 for IrDA connection. You will also have to change the speed settings to match that on the PC. You should have "IR activesynch" icon under start - programs -connections. Tap on this to connect through the IR port.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
Activesync Problem, Help Pls
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Em500 Language
It is possible to change menus and basic controls to english - you have to install a windows add-on software (that changes your keyboard layout and local settings. Try http://www.penreader.com/company/productmap.html Their Language Extender product should do the job - however, it's not free.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Can't connect EM500 to my laptop computer
It sounds like you are using two different types of USB connections, one for the iPAQ and the other for the Casio. What operating system is running on the laptop? How many USB ports are there? You might have to reboot when you want to change from one USB connector to the other. If you have two USB ports, always connecting a USB connect to the same port (iPAQ #1, Casio #2) might help the OS keep track of what is connected to it.
Casio Cassiopeia EM-500 Pocket PC Logo
128 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
