Question about Car Audio & Video
Amp power my samson S1500 will not power up. i've checked all of the fuses that i can see with the top cover off, and they are fine and the circut breaker is not tripped. im stuck my rockford punch 1200 w will not switch off from its protect mode. everything seems fine and the problem occured when i put in a new car battery... dont no if that has anything to do with it.
    Champion:
  • 232 Answers
If one amp powers up and the other one doesn't in the same car,it tells u its not the wire, both amps seem to be damage and will require repair.if your having problems with amps u are over demanding the amp for power. try higher ohm speaker configuration for less amp break downs
Posted on Aug 30, 2008
Wiring no power on anything
Hi Anonymous, it is a 30 amp circut breaker located next to the rear mounting plastic lug of left side cover. Good luck
Feb 22, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
Solution for x5 e53 no power to dash, ignition, front lights ele windows
their could be two problems first it could have been the new stereo it could have been it was to power full and made the car malfunction or it wasn't wired proply and made it shut down the car so go back to where you got it fitted in and ask if it can be fixed
Nov 09, 2013 | Cars & Trucks
I have a s1500 samson amp I keep blowing speakers, what can I do to prevent this from happing again? The speakers that blown first was two 12'' yorkville 350 w impedance 8 ohm, the next speakers that blown...
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Feb 07, 2011 | Crown XTi 2000 2-Channel Amplifier
Ineed to replace the 12 volt fuse on my dometic refer and don't know what size fues to use.....
If you are talking about the fuse on the circut board, it tells you the size on the black cover, covering the circut board. I think it's a 1 amp and 3 amp glass fuse.
Dec 29, 2010 | Dometic NDR 1292 Refrigerator
Fuses keep blowing on my Samson Servo 120a
If after putting in the right rating of fuse you have a blow out, then you must diconnect the speakers and test. If the fuse hold ok then the speakers must be checked for shorting or fault in the network. However if the fuse still blows off, then you will need to take out the cover to test within the main board for the power section or output section malfunctioning. First of all discconnect the power to the output stages and test, if fuses blows check the powersuppy section, the rectifier to the main capacitors for reduced values. If not check on the output stages, the drivers, the predrivers for malfunctioning. However you will need some knowledge of electronics to probe stage by stage to isolate the fault.If not get help to proceed. Good day
Aug 03, 2010 | Samson Servo 120 Amplifier
Need fuses for samson amp
The manual recommends 4 Amp Slow blow for 115 volt operation or 2 Amp Slow blow for 230 Volt operation for the 201a.
http://s3.amazonaws.com/samsontech/related_docs/Servo201a_OM_5L_v1_1.pdf
For the 260 Amp manual shows 10 Amp normal for 115 volt operation and 5 Amp nomal for 230 volt operation.
http://s3.amazonaws.com/samsontech/related_docs/ACF1AAF.pdf
Dec 31, 2009 | Samson Audio Players & Recorders
I need to change a fuse
You can test fuses without removing them by using a test light and probing the small openings in the top of each one at each end with a test light. it takes about ten minutes to test all of them so any one that does not have power on both ends is bad and needs to be replaced. Lighter will be at least a 25 amp fuse or sometimes runs off a circut breaker. (little metal covered fuses usually at the top of fuse box) Breakers need to be tested with a continuity tester or can be powered on one spade and checked with a test light touched to other spade.(when removed)
Mar 19, 2009 | 2001 Mercury Sable
Dell w4201c burning fuse...
hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Jan 10, 2009 | Dell W4201C 42 in. Plasma HDTV
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
