Question about Kodak EASYSHARE 5100 All-In-One Printer
Server failed printer won't print
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Is this an" RPC Server Unavailable" error under windows? Be precise w/ your question.
Posted on Nov 15, 2008
Tip
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
on Mar 02, 2008 | Linksys Wireless-G WPS54G Print Server
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
I have a pending print job in my thermal printer and it won't print. I can't delete it from the que
Go to the Start run window and type Net Stop Spooler and press return and then do teh same and type Net Start Spooler after doing this try and redelete the job, if this fails do another Net Stop Spooler then navigate to C:\WINDOWS\System32\spool\PRINTERS and delete all the files in this folder then do a net start spooler all jobs should now be gone, Be aware that option 2 will delete all spooler jobs, so if this is a shared printer or server that these jobs will be lost
May 11, 2011 | Zebra LP 2844 Thermal Printer
Printer says offline. how do i get it back online so i can print
if its wirelsess ??? through a print server make sure its connectd all the way throughif that fails reboot print server and reboot printer....hope this helps kev
Nov 27, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
I have a Lexmark X3550 printer and need a wireless adapter card, but cannot find this anywhere since Lexmark no longer carries this part. Is there another wireless adapter card that would be compatable...
Try E-Bay, you might be lucky.
Failing that, you can try using a LAN print server, connect the printer to the print server and connect the printer server to your LAN.
Then any computers on your LAN can print to this printer.
OR
Connect the printer to your computer and set it up as a shared printer and if your computer is connected to the LAN then any computer can print to this printer provided you computer and printer are switched on.
Sep 18, 2010 | Lexmark X3550 All-In-One Printer
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Failed response from plugin device
Dirty fix...
When the printer errors out...stop, unplug the power to the printserver. Reset the printer, Clear the print que (delete jobs/restart print spooling service), restart the printserver software and plug the printserver power back in. Wait for the re-detect. Everthing should be good at this point. Unfortunatly the print job will be lost and you need to print again...BUT, NO REBOOT yea!!!
Note... for me, if this sequence is not followed, I will have to reboot. The printserver will be locked for the PC that was trying to print. All other PC's will be fine, and I have no idea why.
Good luck,
Bill
Jun 24, 2009 | Zonet MULTI FUNCTN USB 2.0 PRNT SRVR...
D-Link DP 301U Print Server not continuous print from vista
Make sure you have byte counting enabled if you are printing through LPR.
Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Kodak EASYSHARE 5100 All-In-One Printer Logo
112 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
