Question about Casio Cassiopeia E-100 Pocket PC
Screen problem with my Cassiopeia E-100
When I'm turn on my E-100, the top of the screen is always gray. The touching habilities of my PDA in the gray area are still in function but I can't see anything. Is there a solution to repair my PDA? Thanks for your help!
    Master:
  • 551 Answers
Here is how I fix the problem. It seems that a lot of E-100 have this problem, and the shade gone when you slightly touch the power button. I think Casio give us bad LCD or something. I use a little band of paper, rolle it to make it thick and then push it agains the LCD cable, closed to the power button. The thick paper is actually against the LCD cable and the Casio cover, pushing the LCD cable closer toward the screen. You can try this by trying pushing the cable close to the screen. YOu can find at a place, wehre you touch it, the shade is gone.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
Well, there is good news and bad news.... The good news is that your digitizer is working okay...the bad news is that you lcd isn't. This is due to three possibilities... 1. The video controller on the motherboard is bad...unlikely 2. The ribbon cables or connectors that attaches the lcd to the motherboard is bad...possible but unlikely 3. The lcd itself is shot or damaged...seen it more than once. The only way to really tell is to find someone else with another unit and just start swapping out pieces until you can rule out the trouble. Or in the interim, it is possible that the cable just jarred loose a little or has become dirty, preventing full contact. Simply disassemble the thing, clean the contacts, and put it back together...not hard to do, but not for the feint of heart either. Good luck, hope you get it fixed. p.s. Don't be afraid to take it apart...what can you loose, just be very careful to document each step if you haven't done it before. I've done it a couple of dozen times on various Casio E-1XX machines and never had any problems yet....
My tungsten E2 will not go out of the "tap center of the target" mode. Can this be fixed ? Thanks for the help.
Hello, cleme_z. I would be happy to help! Unfortunately, I too have had this issue with a pda of mine (not the same brand as yours), and the reason why my pda did this (and probably why your tungsten is doing this) is because your touch screen is broken. You screen cannot recognize nor truly feel touches, so your pda is stuck in "tap center of target mode," waiting for a response from your touch screen. The best thing to do is to contact the manufacture and tell theme about this issue. They might even allow you to send them your pda and replace it for free if they discover that you might have a slightly defective screen. I hope this helps! If you have any other questions, please ask!
Jan 16, 2010 | Palm Tungsten E Handheld
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
Touch screen issues
i recomend either a flip cover(if available) or a thick screen protector that lowers sensitivity.
Feb 24, 2008 | Audiovox PPC 6700
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
BE-300-How do I open it to remove the touch screen?
As I remember it has some plastic bulges that fit into some indentations. Some gentle prying toward the bottom should show you some success. To get the things that hold it together apart you need to press in on one part and lift up on the other, but don't remember which. If you don't get it email me and I will go dig my old one out of the junk box and see which is which. It, by the way has a good screen/touchscreen I think, the light circuit got busted on it and I can't get parts.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
http://youtube.com/watch?v=l0TT5CnbwBQ
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 dark screen
Bingo! You hit the problem on the head. If you can still see an image, albeit extremely faint, and the Casio is still working, i.e. playing an mp3 file or whatever, then you definitely have a problem with the backlight. More times than not, this is either a daughterboard problem or a connection problem (rarely have I seen an actual bulb failure though it can happen). One of the more common causes is the tiny ribbon cable connector on the daughterboard. You might try to disassemble it, clean the contacts of the ribbon and reassemble the device. I've also heard of people squeezing in the side of the case to temporarily effect repairs...this is normally more ominous.
Casio e-100 questions......help!
Are you trying to install programs that run on your desktop to the pda? If that's the case, you cannot do it. The softwares for pda need to be written and compiled for your particular cpu and os.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
E125 screen failure symptoms
As a rule the failure of the LCD on a Casio pertains to greying out of the top 1/3 portion of the screen. The touch screen - the part that senses your stylus inputs i.e. taps, double taps, tap & hold / drag continue to work. Seems like the failure is not in the LCD but the fluorescent lamp at the top end of it. It could be the lamp itself or the inverter circuit. Have an experienced technician check the lamp out. It is not a very diffucult item to replace. Nor is there any desoldering / soldering involved.
Casio Cassiopeia E-100 Pocket PC Logo
60 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
