Question about GPS
My mio c310 gps unit is broken. my grandaughter pulled the cord and right where it goes into the unit wont get a connection now.
I took it to the shop
Posted on Aug 27, 2008
My mio 320 is stuck on transfer mode when connected to charger it thinks its connected to computer
I've had a lot of issues w/ the operation of my MIO C320, including this problem ... but ONLY whenever I tried using any other mini-USB cords (like from my phone or Garmin GPS chargers), with my MIO C320. There's something unique about the mini-USB pin-out configuration MIO uses that allows you to either charge or update their units (using the transfer function), using MIO's supplied mini-USB cables. (I've labeled my MIO cord as "MIO GPS", on a piece of masking tape wrapped around the cord.) I'm trying to recall whether the MIO's cords worked properly w/ all of my other devices, and I can't think of any that did NOT function properly. So, maybe you could experiment and - if that's the case w/ your devices also - avoid further issues by keeping JUST the MIO's charger in your vehicle?. Sorry this is so late, but I hope it helps! Cheers, The Foxxx
Jan 08, 2014 | Mio GPS
How can i get a manual for my c310
Try this link:
http://service.mio.com/M0100/F0110_FileReader.aspx?fileid=102591
Feb 23, 2011 | Mitac Mio C310 GPS Receiver
Mio C310 maps are out of date
from mio online or from mio distributors - harvey norman etc. Your software will be updated to miomap2008 also (which is the same as the navman software).
Feb 19, 2010 | Mitac Mio C310 DigiWalker GPS Receiver
How do I upgrade my c220 PDA nav system.
mio just offered update for $59.95 at mio.com
Jan 31, 2010 | Mitac Mio C310 DigiWalker GPS Receiver
Replace battery on mio C310 gps
Hi
Thanks for using FixYa. The battery replacement in Mio C310 Gps is fairly easy. You can perform the repairs if you have the following equipments--
Tools required: -precision screwdriver set -wire (24 gauge or smaller) -shrink wrap or electrical tape -wire cutters/stripper -multi-meter -sharp utility knife
Please follow these steps--
  • Remove the rubber caps and two Phillips head screws at the bottom of the unit (don’t lose the screws!) Gently pry the back off starting at the bottom and then work your way up the sides. If you hear the sound of crunching plastic please re-read the first word in the above sentence.
  • Once the back is loose you can pull it down and then away from the main body. Be aware that the speaker wire will prevent complete removal of the units back.
  • Disconnect the speaker wire plug from the main board and set the back of the unit aside. The only thing holding the circuit board in place is the USB port. Simply pry the bottom of the case slightly and lift out the circuit board. There is a ribbon cable attaching the circuit board to the display so be gentle with this.
  • Six clips (three on top and three on bottom) hold the screen in place. Pry the top clips back slightly and remove the screen. Now you’ll be able to remove the batteryu and install a new one.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Mitac Mio C320 Car GPS Receiver
I live in Australia and I purchased a MIO C310 car navigation system in Aug 2007. I would like to upgrade the map to the most current available, How do I purchase it
I did not solve it, I didn't realize that there is no simple internet sight that I could find to upgrade the map so I give up and use what i have. Thank you
Sep 17, 2009 | Mitac Mio C310 DigiWalker GPS Receiver
Need mio digiwalker c320 owners manual
it's on your c/d that came with unit or go to http://service.mio-tech.com/
May 08, 2009 | Mitac Mio C310 DigiWalker GPS Receiver
Mio C 310 GPS lost signal
try rebooting by turning off switch on back and turning back on.
Call mio support for additional help. they are good.
Jan 22, 2009 | Mitac Mio C310 GPS Receiver
Mio Digiwalker C310
Turn off the power switch on the bottom of the unit for at least 30 seconds
Aug 25, 2008 | Mitac Mio DigiWalker C310x GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
