Question about Lexmark X6170 All-In-One InkJet Printer
When i go to print something,a pop up says to check usb cables,connection or restart computer,everything is fine but still isnt working recently.
Same as above
  • mammasgirl71 Aug 27, 2008
    when i go to print a document,i get a pop up saying check usb cables,check connections,or restart.i have done all 3 and all is fine and i still cant get documents to print or scan or fax.it is showin g my lexmark is offline.
    Sergeant:
  • 390 Answers
Check to see if your printer is set to work offline or not. If this is not checked your printer will only print from outside sources such as the internet. You can check this by right clicking your printers icon in my computer and scrolling down to properties. You will not be able to print anything until your pc believes it has got a connection. At present it is not commnicating with your printer for one reason or another. If the above fails, try unistalling it and reinstalling it and se if this corrects the issue. Post back if you need help in thsi or it does not correct issue.
Posted on Oct 28, 2008
My printer scans and previews fine, but it won't send the document to my computer. I've tried using the Lexmark Imaging Studio all-in-one 4300 and it won't work, I keep getting this error message and I've...
it's probably because the scanner isn't configured well in the computer. What you should do, while to printer is turned on and connected to the computer is to go to the device manger (right click on "my computer" or "computer", and then go to the tab named "device manager"). go to "universal series bus controllers" and press on the plus sign. you should then have a list, search for "USB composite device" in that list. when you find it, right click on it and then left click on "uninstall" or "remove", approve it (press yes or OK) and after it done, disconnect the usb cable that connects the computer to the printer and restart the computer. only after the computer is booted up completely, you should reconnect the cable. after you do that you should get a pop up that says that new hardware is being installed (or something like that). wait for it to finish and after it says "you new hardware is installed and ready" (should appear near you computer clock), try to scan, it should work fine now. Good luck!
Jan 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
Printer worked fine now it doesn't
If its a USB printer, try pulling the USB cable out and reinserting it again.
Jun 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Mar 14, 2009 | Dell Inkjet 720 Printer
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
I am having trouble scanning with my hp printer.
You may try restarting your computer with your printer connected and turned off, or ensure that you choose officejet 5510 series and not 5510 twain in the scanner wizard. If this does not help, try reinstalling the printer from scratch.
Jan 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Lexmark X6170 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
