Question about HP Compaq dc5100 PC Desktop
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
When turn on my PC, nothing shows on monitor. Motherboard sound 3 beeps 3 times and power off the PC automatically. Please help.
  • willi1world Oct 04, 2008
    when i turn my computer on the screen just go blank. I cant access the menu bar.
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
Gracias amigazo. Hice esto y funcionó perfecto.
Thanks friend ! I did it and the problem was solved.
Posted on May 22, 2009
1 beep = "happy" beep 3 beeps = bios error constant beep = key stuck on keyboard
thats all i remember
Posted on Oct 30, 2008
    Brigadier General:
  • 5,158 Answers
Bad memory or the bios is wrong. what exactly is the beep code again ?.
Posted on Aug 27, 2008
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
3 beeps
This pages lists ASROCK beep codes and says it's a memory read/write error.
Nov 14, 2009 | Asrock K7S41 Motherboard
I hava a asrock board k7s41 beeps three times cwhats wrong with it started by a change of mem
3 beeps means problem with the RAM. If u recently changed them, check whether they are clipped in their slots properly. If need be remove them, gently clean the contact points with a piece if clean paper & reinsert them in their slots carefully. I hope they are matching pairs with the same FSB..........sodeep
Jun 13, 2009 | Asrock K7S8XE Motherboard
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
Asrock k7s41cx
Replace board as sounds like it has died
Jan 06, 2009 | Asrock K7S41GX Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
Beep Beep Beep
How many beeps? There should be a sequence of beeps. Are they all the same, or are some short beeps and some long? Please clarify so I may help you further.
May 22, 2008 | Asrock K7S41GX Motherboard
Powers on for a second and shuts down
i am getting you this manual cause you can check what i am about to tell you here. make sure the jumper plugs are on the correct pins and that the BIOS settings match the configuration you have and especially make sure the power,reset,led,led2,powersw,speaker,sys pins that come from the power button and so on are over the correct pins on the motherboard!
good luck!
Oct 10, 2007 | Asrock K7S41 Motherboard
Asrock k7s41gx
it seems to me its a dust problem. any beeps?
Sep 13, 2007 | Asrock Motherboard K7S41GX for AMD...
HP Compaq dc5100 PC Desktop Logo
2,200 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
