STARTUP ISSUE ON TOSHIBA 4015CDT
I REMOVED WINDOWS 2000 FROM A LAPTOP SOMEONE GAVE ME IT WAS ORIGINALLY WINDOWS 98 SO I REFORMATTED THE HARD DRIVE BUT NOW IT WONT BOOT UP FROM ANY DISK ON THE CDROM IT SAYS ALL OF THEM ARE INVALID 98 2000 AND XP I TRIE DTHEM ALL
Your BIOS is probably not set to boot from a CD-ROM. Luckily I have the same laptop so if you press and hold the "c" key when it boots up and keep holding it until it beeps at you it will then boot from a cd. You could also press esc and go into the BIOS if you're adventurous.
Posted on Sep 25, 2008
    Brigadier General:
  • 5,158 Answers
Fdisk and format from a floppy. it's still looking for the original disk i would guess.
Robert
Posted on Aug 27, 2008
My system hp pavilion g4. It doesnt get startng. Its shows nly startup menu. Does not opening. What to do now..? I cant even select the system recovery option. No use..
I would recommend getting an external drive case for your laptop drive, and use it to backup your important data to another computer.
It should be easy to remove your hard drive from your laptop.
You need to remove two or one screws from the bottom of the machine. The separate rectangular area located in a corner of the laptop, indicates the position of the drive.
Then, move your disk back to the laptop and boot from cdrom to reformat. It is better, if you have an original win 7 dvd use the windows original cdkey that you find on a sticker in the back of the laptop.
Sometimes you need to remove the battery from the laptop to find the sticker.
Aug 29, 2014 | Computers & Internet
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Mar 21, 2012 | Toshiba Satellite L455D-S5976 Notebook
Windows 98 I have no usb support,I reformatted hard drive a while back on old toshiba sattalite laptop it went back to windows 95 then I istalled( upgrade to 98)
You are having a driver issue. Whenever you reinstall an OS or upgrade this is a recurring problem.
1.
open system properties / hardware / Device manager
2.
scan over your list and notice any highlighted entries
3.
Right click on a highlighted entry and select update driver, if it ask "can windows connect to the internet " select yes.
4.
after all updates are completed reboot your system.
5.
Enjoy
Please rate very helpful if this helps your problem. ^_^
feedback is appreciated.
Oct 06, 2009 | Microsoft Computers & Internet
No windows xp
You will have to reformat it again. its likely a bad sector has been created on the hard disk, and windows file is probably occupying the bad sector. Try to reformat your hard drive. If that doesn't work, try to reformat it with windows 98 bootable disk. If it doesn't work, get another hard drive and test to see if it will work. If that works, then know you may have lost the MBR (Master boot Record) of your hard drive.
Apr 14, 2009 | ASUS A6J Notebook
I have /had Windows 98 on my computer and a friend installed windows xp. I tried to get rid of Xp but lost Win 98, I have the original RestoreDisk for my compaq but it will not let me install to get back...
Have you tried booting the system with the restore disk, well it should reformat the system before it installs a fresh copy of windows 98 so you should back-up data before proceeding and check the boot sequence in your bios, set the first boot device to CD/DVD.
I hope this helps:)
Oct 20, 2008 | Compaq Computers & Internet
Toshiba startup
This is one of two things, 1- an operating system error or glitch, a system repair with your recovery or operating system disc will fix it, or 2- a hard drive failure. If the system repair doesn't work, then reformat the hard drive and install a new operating system. If the drive will not format, or you have any issues during or after the install, then the hard drive is bad and will need replaced.
Aug 26, 2008 | Toshiba Satellite A135-S2386 Notebook
Keyboard problem with Toshiba Satellite Pro 480CDT (running Win98 SE)
I found a BIOS upgrade download for the Toshiba Satellite Pro 480 on Toshiba's website under the archived old models listing. I downloaded it on a different machine and saved it to a USB which I then used to copy to the problem laptop and ran it there.
Jul 04, 2008 | Toshiba Satellite Pro 480CDT Notebook
IBM thinkpad 600e error - upon startup a explorer error is encountered
hi jono ......like java name
restart ur comptr, press F5 to entering safe mode
uninstalling your dispaly adapter first,
and
restart your computer again
oke
suwun , cropp
Mar 21, 2008 | IBM ThinkPad 600E 2645 Notebook
Satellite pro 4600 windows 98 fatal error
What OS are you running on the system? Did you recently install any hardware? If there is a recent hardware install, remove it and try powering on the system on.
If this fails, then you'll need the restore CDs/DVDs from the manufacturer. This will bring the laptop to it's factory default installation. Before doing so, I recommend purchasing a hard-drive enclosure for a laptop hard-drive and backup all important data.
Hope this helps :)
Nov 25, 2007 | Toshiba Satellite Pro 4600 Notebook
Problem running the restore disk for Toshiba A85-S107
I have the same model and i just reformatted the hard drive with the original restore disk and it does loop around several times. That is the way it is suppose to do on this particular restore disk. So don't be afraid if it goes around several times because it is doing different tasks each time it loops.
Nov 19, 2007 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
133 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
