Question about Texas Instruments TI-89 Calculator
Dimension Error Hi, whenever I enter my data into the lists and try to attempt a regression, it tells me that I have a dimension error and refuses to do anything. I don't know how to get rid of it. Thanks for your time.
  • Anonymous Oct 23, 2008
    I have a dimension error on my TI 89
  • Anonymous Jan 13, 2009
    If i try to factor something, it will always tell me i have a dimension error
I had this problem. What fixed it for me was clearing all of the lists in the Statistics application and also in the stat app in the f2 pulldown menu select Plotsoff. After that it worked fine
Posted on Nov 28, 2008
I simply made certain the plot used cooresponded to what was open in the stat app. This solved my problem.
Posted on Oct 15, 2009
What to do when error;invalid DIM shows up on the screen?
INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press 2nd (stat plot) ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Sep 13, 2014 | Texas Instruments TI-84 Plus Calculator
Error 12 on regressions
ERROR 12 DIM MISMATCH
You attempted to use two or more lists, matrices, or vectors as arguments, but the dimensions of all arguments are not equal, such as {1,2}+{1,2,3}
Dec 04, 2013 | Texas Instruments TI-86 Calculator
Error 13 dimension
From the manual:
  • You entered an argument with an inappropriate dimension.
  • You entered a matrix or vector dimension less than 1 or greater than 255 or a non-integer.
  • You attempted to invert a matrix that is not a square matrix.
If you can't figure it out from here, please reply to this post telling us what you were doing or attempting to do when you got this error.
Nov 03, 2010 | Texas Instruments TI-86 Calculator
Ti 86 error 13 dimension
From the manual:
Nov 02, 2010 | Texas Instruments TI-86 Calculator
Everytime I try to graph on my calculator it says ERROR 13 DIMENSION. How do I fix that?
From the manual:
If you can't figure it out from here, please reply to this post telling us what you were plotting or attempting to plot when you got this error.
Sep 17, 2010 | Texas Instruments TI-86 Calculator
When i try to graph anything, EEROR 13 DIMENSION comes up! what do i do??? i neev my calulator to wokr , i have a tst tomorrow! :/
From the manual:
If you can't figure it out from here, please reply to this post telling us what you were graphing or attempting to graph when you got this error.
Sep 09, 2010 | Texas Instruments TI-86 Calculator
Error 13 dimension
From the manual:
Aug 28, 2010 | Texas Instruments TI-86 Calculator
In statistic mode when i try and make a graph i press set then sel draw and 'dimension error' comes up!
It is most likely that the lists you are using as input data are of unequal lengths: One has fewer elements than the other.
I just created a small data set in two lists of unequal length. I was able to draw the scatter plot, but when I wanted to get a regression curve the error message popped up.
Jul 09, 2010 | Casio FX-9860G Graphic Calculator
How can I solve an error 13 dimension, when I need to seea graffic. Thanks
From the manual:
Jun 06, 2010 | Texas Instruments TI-86 Calculator
I am trying to graph and i am getting error 13 dimension how can i fix it?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features.
Press GRAPH F1 to enter the equation editor.
Plot1 Plot2 Plot3 on the top line of the equation editor displays the on/off status of each stat plot. When a plot name is highlighted, the plot is on. To toggle the status, press up, left, and right to place the cursor on the name, then press ENTER.
Sep 30, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-89 Calculator Logo
2,552 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
