Question about Kenmore 63932 Electric Dryer
Kenmore dryer Model C110-8170091
My older model Kenmore dryer went from working perfectly to suddenly stopping with a beep after a second of being turned on. I do not have a manual for it... Can you help me?
  • Lee Hamilton
    Lee Hamilton Feb 27, 2016
    This was made by Sears Canada. Unfortunately can not find online parts list or schematic. The one on back of drier is very old and torn but almost readable (part labels are in English and French). Preliminary resistance testing indicates the belt switch to detect a broken belt may be open. Will check hot when someone else is here to throw the fuse panel switch. Electric dryer Model C110_8170091, Serial 9GG39617 Type DR_6 with Kenmore on front panel. An equivalent parts US dryer might be an alternative to get the correct parts
  • Kenmore Master
  • 17,155 Answers
This is most likely the door switch that has failed or come loose
Posted on Feb 26, 2016
  • Lee Hamilton
    Door switch seems ok, will recheck it with power
catriver
  • 878 Answers
SOURCE: Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Posted on Jul 16, 2007
  • 94 Answers
SOURCE: kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
SOURCE: Kenmore Elite dryer won't run
take off rear panel. check drive belt.
Posted on Nov 30, 2008
How do i stop a Kenmore model 417880042700 beeps while drying and continues to beep when dryer not running?
Sounds like a touchpad/user interface issue...The buttons will push themselves and the unit beeps as if cycles are being chosen
May 16, 2016 | Kenmore Dryers
Kenmore 88042 dryer beeps non stop
What is the complete model number of your unit?
Dec 01, 2012 | Dryers
I have a Kenmore Elite dryer. Model # 110.67082600. The dryer has not been used in two days and I noticed it beeping. I unpluged it and plugged it back in. It did the same. It seems to run but after...
If you have a little bit of knowledge mechanically you can unplug the dryer and pull the top off by removing the 3 screws across the back at the very top, slide it back and lift it off. Inside of the dryer, at least in mine, there was a plastic folder on the inside with tech instructions that list the fault codes and it also tells you how to run a diagnostics mode on your dryer. Hopefully this will help you at least determine if it is something you need to call a tech to fix.
Aug 06, 2010 | Kenmore Elite HE4 Electric Dryer
Push to start switch does not work
That is a bad motor. Run winding is gone. This video shows how to replace it on a newer model:
http://www.youtube.com/watch?v=tm1ZCiAnxto&feature=player_embedded
This video shows how to get to it on older models:
http://www.youtube.com/watch?v=LiXD8euFteQ&feature=player_embedded
Jul 08, 2010 | Kenmore 73952 Gas Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Kenmore Gas Dryer Model #98042 beeping a code
I had the same issue and (I think) I fixed it by taking the filter out and washing it with warm water to remove waxy buildup (per manual). It did not make any more beeping noise when I re-ran the load (so far only 1 load)
Oct 10, 2009 | Kenmore Dryers
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Kenmore 63932 Electric Dryer Logo
709 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
