RCA Convergence board?
Do you know where I can buy one?
    Genius:
  • 2,920 Answers
You can go throgh the rca website to order one or to a local appliance dealer
Posted on Aug 27, 2008
When the picture has four colored lines and then the picture arches
This tv have convergence problems,it dead.The tv convergence board must require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits,com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 30, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA D52W23 Color Alignment. Blue,Red,and
Its problem of convergence board and need to be replaced. You can buy this board at Part Store.
Please replace the board if you have basic electronics knowledge or get help of tech person.
Regards,
Sep 19, 2008 | Televison & Video
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Autoconvergence will start and then stop within 3 or so seconds. This is a 52" rear projection. Colors are a little off.
Ur tv convergence are dead.The convergence board require the 2 STk convergence ICS and some or all it resistors.Must be change to solved convergence problems.U have soldering tools,solders,and know how do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 18, 2010 | RCA HD52W66 Projection Television
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
2002 rca d52130 tv has convergence problem
leave a email at this site with the full model number and your symptoms. They will be able to get the parts that you require if anyone can. Heres the link
http://servicemanuals.vstore.ca/
Sep 28, 2008 | Televison & Video
Convergence power supply board
try www.partsstore.com they should have the board you need if its still available from RCA
May 25, 2008 | RCA TH1101 MP3 Player
BAD CONVERGENCE BOARD
yes you can but the going rate for this fix is 250-350 if you would like to fix it your self let me know and ill give you step by step k good luck
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
