Question about Belkin Computers & Internet
I have a Belkin F5D7230au4 wireless router and have just recently changed broadband providers. I have been into the router configuration page to change settings, but can't find where to change some of them (such as ADSLmode = G.dmt , v=, pi=) So I can't connect. Any ideas if this is possible, or do I need a new router?
  • cka3 Aug 27, 2008
    I've worked it out and am now connected. Thanks
  • Belkin Master
  • 3,051 Answers
If you go to configure like you are in ,, then go to advanced now look down the list and ensure at everything is enabled very importamt this is the section that you are talking about too also check the regions a and g i had to resert mine to around the 165 on a and 1 thru 11 on g ok also make sure everything else is enabled it the setup of the router this will help get you to the connecvtion easier ok best regards mike
Posted on Aug 27, 2008
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
Tip
How to fix the problem with Belkin Next generation Routers ?
How to fix the various issues with Belkin Basic, Surf, Share, Play, PlayMax Routers ?
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
On the left side below the "utilities" select firmware update and check the current firmware version of your router.
In these updated firmwares all the problems related to various issues have been fixed.
download the latest firmware and update it.
After updating the firmware click on restore factory defaults found below the "utilities" and restore it.
then configure your router according to your internet service provider...
For Cable ISPs click here...
For embarq and centurylink ISPs click here...
For DSL & Satellite ISPs click here....
To configure the wireless part except for play & playmax click here...
on Jul 24, 2010 | Computers & Internet
Can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
Sep 02, 2012 | Computers & Internet
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
Sep 29, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Configuration of Belkin Wireless Router F5D6231
Whoops, found it. http://cache-www.belkin.com/support/dl/f5d6231-4_manual.pdf
If I were setting this up for myself or a customer, I'd keep the Airtel IP's and let it be the DHCP server. To do this, you pick a fixed IP address for the Belkin, something like 192.168.1.251. Log into the Belkin and change the LAN IP address to that and turn off DHCP. Those instructions start on pdf page 34.
Now, plug one of the 4 ports into the Airtel, and from a computer connected to the network type in 192.168.1.251 in Internet Explorer. It should get you to the Belkin where you finish setting it up for wireless security and password from page 38.
You won't use the WAN port.
Carl
May 31, 2009 | Belkin Wireless Cable/DSL Gateway Router
No wireless connection :(
If you have your broadband configuration info written down, you could try resetting your router to the factory default settings and then re-configure it.
For most broadband connections, the default settings will work OK, but you should configure your router with a secure administrator password and wireless key.
The user manual for the router as well as configuration software can be found here:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Feb 04, 2009 | Belkin (F5D7230-4) Router (587009)
I lost my belkin install cd
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
