Question about Panasonic NV-DS29B Mini DV Digital Camcorder
Dew warning on Panasonic NV-DS29B Mini DV
Dew warning and camera shuts down after approximately 5 sececonds. Where is the dew sensor located and how can i convert it?
I had the same problem, and solved it by having the heads cleaned.
Posted on Nov 05, 2008
Manual dew instrucciones
Use a hair dryer to blow warm air into the unit. Do not heat the unit but allow only warm air to circulate so as to remove any dew formation within the unit that must allow the unit to reset the error.
Jan 09, 2012 | Panasonic NV-DS65 Mini DV Digital...
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew symbol on panasonic NV-DS60
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Nov 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Exact location of dew sensor for panasonic NV-DS29B
You can easily locate it pasted on the mechanism , either on the motor driving the mechanism or nearby capstan motor.
Sep 04, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew problem
it is on the mechanical section and have two connection,use a 1k resistor to convert it..
Aug 23, 2008 | Panasonic NV-DS29B Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Feb 26, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Condensation warning indicator
the dew sensor is already malfunctioning....solution convert or replace the sensor...
Oct 15, 2006 | Panasonic NV-DS27B Mini DV Digital...
Panasonic NV-DS29B Mini DV Digital Camcorder Logo
240 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
