Question about Casio Cassiopeia E-100 Pocket PC
Casio E-100 didn't power up.
My casio e-100 cannot power up at all. Even though I tried ti charged it, there's no light at all. I've changed the backup battery... is it the main battery that is faulty???
  • Donalda42 Jan 18, 2009
    My Green LED lights up when I plug the AC adapter in but the yellow LED doesn't come On. Could it be that the main battery needs to be replaced ?
    Master:
  • 551 Answers
Try this Does the yellow light come on when you plug the charger in? If so, leave it charging for 2 hours, then do a hard reset while charger is still plugged in. I think, on E-100 it involves holding down Power button, while pressing reset button on the back of the unit with a stylus for a few seconds. Warning: you'll lose all your personal data on E-100 this way - but then again, it's probably lost already.
Posted on Sep 06, 2005
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
Nc6000 when ac disconnected, computer shuts down even though battery charged 100%
Hello, if on XP, go to control panel and open up 'Power Options' and look to increasing the 'Running on batteries' settings. However, you don't say whether it will power up without the mains connected...if it doesn't then maybe you've a bad/poor battery connection, ie it will display a voltage to the monitoring system, but won't allow any current to be drawn....this could be due to a bad connection so it may be worth removing the battery, taking a look at the connectors (maybe wipe them clean) and then refit and try again. Best of luck Nicam49
Jul 27, 2011 | HP Compaq nc6000 Notebook
There's something wrong with my TI-83. When I'm typing up an equation it will randomly shut off. And when it's on it will have shown that the RAM was cleared. Now it sometimes takes like 5 presses of the...
Have you tried changing the batteries? I'd try that first thing. From your description, the problem sounds like you have low batteries. The RAM shouldn't clear itself when you turn the calculator on unless you tried to turn it on when the calculator didn't have any juice. The TI-83 has four AAA batteries and one CR1616 battery it uses for memory backup. The CR1616 isn't enough to power the calculator, just enough to keep your calculator from losing its RAM contents while the primary batteries are out. If you try to power the calculator on without primary batteries, the backup fails. However, the TI-8x line is usually pretty good about warning you when the batteries are low by displaying a big warning message when you turn it on about the batteries being low and a recommended change of batteries. It might not, though, so you really can't be sure until you try a fresh set of batteries. Good luck!
Apr 09, 2011 | Texas Instruments TI-83 Plus Calculator
Main Battery Power
It cannot switched the batteries. The backup one is a small internal battery just to keep the CMOS with data. That's it.
If you main battery is not charging or when unplugged won't power on, the is likely the main battery is defective, or the charging circuitry of it is failing.
Best regards,
Jul 01, 2008 | HP iPAQ RX3115 Pocket PC
Loss of memory
The back up battery always shows 100%, as far as my experience shows. The backup battery is only utilized to retain memory while the main battery is dead. The backup battery charges first, so if the ppc has enough juice to be turned on, the backup battery should be at 100%, unless it is plugged in and you are just now turning it back on. Even so, it will probably still show 100%.
Basically, you left it on too long and all the batteries died. Sorry, but your data is gone :-(
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
E-125 No Power
are you checking your adapter. i had the same problem with my casseopeia e115. i searched and searched for the battery which even casio doesn't offer anymore. i bought a battery pack which works great w 4 AA batteries but it's bulky and you lose data when you turn off the batteries. i finally went on to discover that my charger/adapter that plugs into the e115 and the serial cradle was scorched by a lightening strike and it was not charging and eventually the batteries DIED!!! I took the adapter to an electronics repair store and for $15.00 they rewired the adapter and it works!!!! it charged the batteries and worked fine.(altho i have to visit them again because i think one of the new wires is bent and i have to position it perfectly to keep charging.) BTW: any one looking for a new casio battery jk210lt...i have a couple to sell! ;-) hope this helps
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio E-100: Dead or alive?
If you had synched the device you have all your data on the desktop pc so I wouldn't worry too much except for some software which may require you to enter the reg info again. You could try the following. Remove both the batteries. Install the main battery. Install the backup battery preferably a NEW one. Let the device charge to the full - until the green charging light goes out. Switch on the device. It should now behave properly. It would help if you generally avoid using the device when you get low battery warning. Especially the backup battery.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 Turns off and won't turn on
This is what I suggest: Get yourself a new backup battery. First backup your Casio. Then install the main battery. Plug the Casio in and recharge overnight. Once recharged, install the new backup battery. Make sure you do not touch the battery with your hands. Use a tissue. This should solve your problem if the Casio is not physically damaged.
Casio Cassiopeia E-100 Pocket PC Logo
213 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
