Question about Sharp Audio Players & Recorders
My ancient Sharp CD - BA150 bookshelf stereo 3-disc CD player has suddenly stopped working. Even with 3 discs in tray, player won't recognize they're there and reads" NO DISCS" on LCD display. What gives?
    President:
  • 624 Answers
I have repaired a lot of these exact Sharp stereo's and can say with certainty that you have a bad laser pick-up. The only cure for your problem is to have the pick-up replaced. It says no disc because that part is bad and can not read the disc, so it thinks there is no disc.
A repair for this would cost in the area of $125 to $150 depending on the rates of the service center you take it to.
This should give you the information you need to determain if it is worth fixing to you.
Sorry it is not something you could fix easy, but that is just the nature of these types of stereo's. That part, the laser pick-up, is a very expensive part. I have no idea why they charge so much for it, but it is killing the repair centers making so many of these too costly to fix.
I hope this helps, let me know if you require any further help.
Dave
Posted on Aug 27, 2008
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Jan 18, 2011 | Sharp CD-BA150 Shelf System
Need to remove slide tray to get at the optisal system.
it has a rotating gear with a stopper on it.there is a limit switch to tell the motor to stop.if you do not set the timing properly,it will be out of sync and will not work.the best way is to remove the top cover,load it to play with no disc in it and you will see the pick up.do not look into it ,it is a laser beam,and can damage your eyes.if you want to clean the lense,get it to load,no disc to come up and then unplug it and clean the assembly
May 23, 2009 | Sharp CD-BA150 Shelf System
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD player fails to read CDs Sharp CD BA150 3 Disc Rotary Charger System : Issue; CDs that are loaded into the trays do not read/play, even though they did previously. Most disks will spin a little while...
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Jan 25, 2009 | Audio Players & Recorders
CD Player returns NO DISK code
looks like the OPTICAL LEN part D.O.A. on you , I suggest to replace the OP LEN , AND SHOULD BE ABLE TO PLAY. hope this helps
Apr 19, 2008 | Sharp CD-BA150 Shelf System
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
Mini sharp stereo
Try pressing the play button on the remote. If it works correctly, the play button on the unit may be defective.
Sep 04, 2007 | Sharp CD-BA150 Shelf System
Since the unit was in storage for a while dust may have settled on the lens.Try cleaning the lens.
Dec 17, 2006 | Sharp CD-XP120 CD Shelf System
94 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
