SOURCE: wait for pressure after trigger is pulled
the pressure releif valve may be sticking. you will need to take it out, clean it, the put it back in. it should have a spring on it. make sure that the valve works smoothly in the bore.
SOURCE: Trigger problems
I have repaird hundreds of nail guns with a problem similar to yours. Depending on the brand and model, the problem can be repaired by checking the following. Headvalve orings should be checked for wear and any surface that the orings contact must be smooth and free from scratches. If the surfaces are scratched try to smooth with fine sandpaper and use light grease instead of oil when assembling. The safety contact foot may not be reaching high enough into the trigger to properly push in the trigger button. Check for worn spots on the trigger that may be filled in with epoxy, loose fitting trigger caused by worn roll pin or retaining pin. Some of the trigger valves as used on many bostitch nailers (tva6 valve) used a plastic pin which contacts the trigger. If this pin is loose or worn the valve should be replaced. Some tva6 valves have a vinyl looking sort of oring that fits too loose on the spool. This vinyl oring in not available by itself but if the oring fits too loose the gun will not fire and leak air. On bostitch remove the trigger and the rollpins holding the trigger valve and apply air to gun to eject valve. (use heavy glove to catch valve as it will come out with force)
SOURCE: jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
SOURCE: mad catz drteam blaster
dude im not so sure about this just one tip is dont ever buy madcatz stuff!! PLZZ!!!
i cant help sorry! :(
SOURCE: how do you calibrate the madcatz playstation 2 sterring wheel
To use the Accudrive feature simply press the eCalibratef button. Two near the center will show the current deadband setting, and two green near each end of the display will show the current maximum range adjust the settings, use the eUp/Downf buttons on the D-pad to deadband, and the eLeft/Rightf buttons to widen/narrow the amount of needed to move the wheel to achieve maximum turning position. The and maximum range features offered on this controller are in addition calibration adjustments which may be made by the game software.
