Question about Panasonic AG-185 Camcorder
Panasonic SD Card reading problem
I've just purchased a Panasonic NV GS 400 camcorder which has the capability to save pictures to SD card. When I connect the camcorder to my PC via the USB cable, I can transfer the images without problem (it appears as a removable disk drive in Windows Explorer). However when I try and access the files via an external file reader (by taking the SD card out of the camcorder and inserting it into the SD slot of the card reader), I can see the top-level file structure folders but not the individual files - Explorer gives me an error saying that the files are corrupt or unreadable. When I reinsert the SD card into the camcorder and connect it to the PC, everything is OK. Has anybody else experienced this problem? And is there a way around it? (I want to be able to access the images direct from teh SD card as it saves the hassle of hooking up the camcorder all the time, and I also want to be able to use a HDD MP3 player which has an inbuilt SD slot as a way of backing up my files when I don't have a PC with me). Also will I have the same problem with a Panasonic Digital Camera (such as the FZ5)? Any suggestions? Thx
    Master:
  • 473 Answers
Yes. The device was not using a standard file system. There usually is no cure. Try this. Format the card in the device and try one more time. Many don't know to perform this step.
Posted on Sep 06, 2005
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
Can I use a 8gig SDHC card in my panasonic nv-ds65 ?
The NV-DS65 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards 2GB and smaller.
May 04, 2012 | Panasonic Cameras
What is the largest size sd card I can use in my nvgs 400? thanks
SD cards max out at 2GB. Make sure you SD cards, not SDHC cards. SDHC cards start at 4GB and go up to 32GB, but they will not work in the NV-GS400.
Aug 05, 2011 | Panasonic NV-GS400 Camcorder
My nv gs200 camcorder not suport any sd card. this problem is comes in few days ago.
That's correct.
Older cameras cannot support the newer SDHC cards.
You camera is most likely limited to a 4 gig card.
Check your camera manaul for specifics.
Mar 15, 2011 | Panasonic NV-GS200 Mini DV Digital...
We are trying to take videos off my father in laws panasonic nv-ds65b camcorder onto our pc in order to transfer them onto dvd. The usb driver has been installed, but the computer will not recognise the...
You can download the still pictures which have in camera's memory card (SD Card). If u want download the video in the minidv cassette u have to use dv port which is in camera through with firewire (1394), another end in computer not usb firewire card. If u want download still picture only u can use usb. please reinstall software
K. R. Rajan
Jan 17, 2010 | Panasonic NV-DS65 Mini DV Digital...
Can you record video to the SD card on the Panasonic NV-GS25?
Yes very easy with a razor sharp knife you will need to cut it in middle.
When you did that you will have this [ ] [ ] if you put in the right part you will record video to sd card and the left side will put pictures on sd card , when ur done just put them together with some tape again and same thing next time
May 08, 2009 | Panasonic NV-GS25 Mini DV Digital...
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Feb 10, 2009 | Panasonic PV-GS500 Camcorder
Panasonic AG-185 Camcorder Logo
219 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
