Vulcan electronic gas heater switches off
My gas heater switches off by it self. It starts fine then after about 1 min beeps and restart sign comes on and about 2 to 3 min. later the heater switches off but it does keep on beeping. It was bought second hand and installed yesterday by a gas fitter.
Can you tell me where I can purchase an instruction manuel
Contacted a gas plumber
Posted on Aug 27, 2008
Could a weak battery cause Throttle position switch sensor error code - after 1 hr drive engine lite on and gas pedal quits, restart car, repeats about 30 min later
no it will not. if the engine light is on check for codes this will help to know which direction to start diagnosing. a weak battery will usually show up on a no start condition. I am guessing the engine light that comes on is the check engine one.
Mar 20, 2015 | Cars & Trucks
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
Fault finding
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
    1.Turn the blower fan OFF.
    2.Press and hold the recirculation control switch and the rear window defogger switch down.
    3.Turn the ignition switch ON (ll).
    4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
    If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
    If the system is ok, the recirculation indicator stays off.
Aug 19, 2013 | Honda Civic Cars & Trucks
Pool heater Hayward H100IDP1 power to gas valve problem
possible gas valve if when quits is there gas pressure if ok make sure not overheating check manual bypass valve
Sep 01, 2012 | Hayward 100kbtu Pool Or Spa Propane Gas...
Oil Light comes on and dings. I shutdown, check the oil levels which are fine, and restart. A mile later the oil light comes on and starts beeping again. No engine noises. Everything sounds fine. Is i
Could be the gauge that having problem,just for cost effectiveness replace the oil pressure switch,if the problem persist you have a gauge problem3_20_2012_6_57_48_am.jpg
Mar 19, 2012 | 2000 Dodge Caravan
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I have a 1997 goodman 3.5 ton outside gas, self igniting heater. the led beep is 1 then a 2 then a half second delay.
I am sure you have gotten this fixed by now. A 1 code is a general lockout meaning it tried to light 3 times and did not. A 2 code is for a stuck closed pressure switch. That pressure switch is normally open. If unit is off, and you remove the wires and using a multimeter, ohm across it, it should be open. If not, it needs to be replaced.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Flame backlash
The burners have an adjustable vent in the front that may have been moved. Also the vent pipe may be inadequate, that is why the roll out switch that you by-passed tripped. If you replace the switch that was by-passed I bet the over flaming stops,as the gas will quit overflowing. Most of these switches have a little reset button on them so look at it next time before you by-pass the wires.
Jan 05, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
281 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
