A local service person is indicating that for warranty replacement of our RUDD external air unit, we must pay for it first, then wait for a reimbursement. Does this make sense? FYI: We are now living in Hawaii, and the unit is is for our California rental home.
Why dont you get the answer from the horses mouth? Give a Ruud dealer a call with the model& serial #'s ! Thank-you-very-much!
Posted on Aug 27, 2008
Ubhb-21j11sfdai: what motor should be in this blower? HP, RPM, Voltage, Amp?
If you have the motor from the blower, the information should be on the motor nameplate. If there's no nameplate or information on the motor. Then to get the correct motor for your blower, you need to call your local Rudd dealer or local parts store. Give them the model number and serial number of the Rudd unit and they should be able to help you.
Jun 11, 2013 | Ruud UBHC Air Conditioner
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Sharp cv-10nh not cooling
I wouldn't recommend servicing this yourself unless you are an air conditioner repair person by trade. If the unit is five years old or less Sharp covers the parts-----you pay the labor for the repair. There is a manufacture code on the unit that will indicate when it was made anyways if you don't have your original bill of sale. If the unit is within its first five years of life you would need to take it to a Sharp authorized service center. If you do not have a receipt you will need to get a proof of purchase letter from Sharp. If the unit is older than five years you can take it to any repair person but it might be cheaper to purchase another unit.
Jul 07, 2010 | Sharp CV10NH Air Conditioner
Rudd Acheiver 13 nothing turns on outside but the fan inside is
Try pushing the red reset button at the outdoor unit near the brass service valves (where the refrigerant lines enter the outdoor unit). Also check for power from circuit breakers furnishing power to the outdoor unit ( the indoor unit has a seperate power supply source ). There may be fuses in the service disconnect box mounted near your outdoor unit. If those "blow" they will prevent operation of your outdoor unit. You can test continuity using an ohmmeter. If you do not have an ohmmeter, you can take the fuses to the local hardware store. They should be able to test them for you and offer replacements if needed. If after doing all these steps you continue to have problems, let us know and we will dig a little deeper. :-)
Apr 18, 2010 | Ruud UBHC Air Conditioner
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="http://mojaizba.com/convert-units-of-flow" title="Flow units converter page on mojaizba.com - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute cu.in/min, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
RUDD MODEL# UAMB-048JAZ AIR CONDITIONER
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
Has not ever run properly
is it a heat pump? I would be suspect of the line voltage transformer have 24v. if transformer is not matched to line voltage you can have erratic problems their is an under lying problem. that is being missed find a good contractor . Tom
Jun 17, 2009 | Ruud UBHC Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
Possible defective Maytag central airconditioner
Defective is a pretty broad term. If the unit isn't working its defective. You should have at least a part warranty. I'm assuming you bought an extended warranty/ labor warranty.
May 26, 2017 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
