Question about Panasonic AG-185 Camcorder
Strange Audio Problem, Please Help if you Can. Going Cuckoo
This is driving me batty. I hope somebody can help me before I jump off the nearest cliff. This is my plea for help!!! I use my DV Camera (Panasonic PV-GS120) to record off the tv, like a VCR. I have it connected to my direcTV using a S-Video cable and a Stereo Y-Adapter (2 RCA's on one end, Stereo MiniPlug on the other) The only problem is that I only get audio on one channel - left channel. I have isolated the problem but cannot for the life of me, figure out why this is happening. On the RCA side of the Y-Adapter there is one black plug and one red plug (obviously). What I noticed is that the audio only works when the black plug is connected. The red plug gives NO AUDIO to the camera (I tested it by listening to the camcorder audio). So I tried it on my vcr. Sure enough same thing, if the black plug is plugged in (on either right or left audio output), then it feeds audio to the left channel of the camcorder. But if I plug in only the red cable, it feeds NO AUDIO. I have tried all camera settings and they do not fix the problem. I am so confused and tired. I don't know what to do. I figure there are only 3 possibilities here: 1. The camera only supports recording from an external source on one channel. I have found nothing to indicate this is the case however. 2. I am using the wrong cables? I have tried 2 sets of cables from two manufacturers. This is a standard Y-Adapter cable. The stereo mini plug has 2 bands on it, the other side has two rca cables (red and black). The other cable is similar but it has red and white rca's. Is there some other type of cable I should be using? 3. The camera is defective. Could it be possible that a camera would only record external audio on the left channel? But then why is it that in regular camera videotaping mode, it records both channels fine? Any help would be appreciated. As I said before, I am going crazy.
    Master:
  • 473 Answers
T could be that the camera has an A/V jack. A/V jacks are 4 segment connectors whereas most stereo cables are three segment connectors. When a three segment jack is plugged in to an A/V port, you only get one channel of audio. That means your cable should have three rca plugs. Two for the audio and one for the video. I haven't been able to find A/V cables or adaptors in stores. The camera probably should have come with one. I had to special order them on the internet.
Posted on Sep 06, 2005
SOURCE:
I have a 2 weight cuckoo clock.the weights are stuck at the top of the chains and the pendulum doesn't swing...help, please.
Probably needs cleaning, but you can try removing the pendulum altogether. Time will fly but the chains will drop. One weight runs the time and the hands, and the other makes the cuckoo work. If it is a good clock, have it professionally cleaned.
see videos
https://www.google.com/search?safe=off&client=firefox-b&ei=M1FvW_2UE4TWjwTqv6D4DA&q=cleaning+cuckoo+clock+movement
Aug 11, 2018 | The Watches
Is the world's largest cuckoo clock in the U.S.?
It is currently in Schonach, Germany. However, the Amish community in Sugarcreek, Ohio is hoping to have them beat with the cuckoo clock they are currently building there.
Feb 11, 2013 | Home
I have only Korean manual for cuckoo crp -m1010fr. Is it possible to get the English one?
please help with my cuckoo rice cooker i don't know how to reset the menu CPR M1010FR i cannot cook my rice anymore
Sep 08, 2012 | Kitchen Appliances - Others
I was driving 2003 suburban I had my a/c going when i shut off the engine i heard a strange whistling noise now my engine sqeaks, could it be from the belts?
might be, you will have to start vehicle lift hood and watch your belts, if they are jumping then they are loos, a pulley maybe going out,also. look at all the pulleys if one is wobbling then it needs replaced. Hope this helped Tim
Apr 24, 2011 | 2003 Chevrolet Suburban 1500
I did not install the driver or anything. i just set the encryption key and thats it. it works fine for a long time and suddenly, it goes cuckoo. i get the message: "application has encountered an...
While it is working get whatever data you need copied back to your main drive then format it with fat32 and copy it back you shouldnt have a problem..........plz vote
Jan 25, 2011 | Western Digital My Book Elite 2TB External...
My car just stop on me it not the battie the lights work when i press the gas it just shots off please help me im in the middle of the road right now noone seem to help me out
I would have the vehicle towed to the nearest Ford dealer to have it serviced.
Any engine light or charge light involved with this issue?
Don't worry, you can get a loaner from the dealer, or could get a rental in the mean time.
Oct 13, 2010 | 2006 Ford Focus
I have an elgin rooster cuckoo clock with serial number 12888. i can't find a database with this information. please help!!
Go to google and put in all the information you have. Some times try different ways to ask the question.. Hope this helps..
Feb 27, 2010 | Elgin 0518709FA
TIME ADTMENT ON MY BLACK FORREST CUCKOO CLOCK
Are you trying to get it in time say to run faster or slower? If so the leaf should just slid up to speed it up or down to slow it down as it is only a friction fit. Hope this helps
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Cuckoo Clocks
you can repair them is their any damaged pieces i will try and get you some diagrams to show you how to put it back together but if you take it to repair shop ie watch repair they will build it for you and get any parts that are broke or they will be able to make them for you hope this is some help i will try find you some diagrams on how it is built i will post you back if i find it but need to know what make and model no if poss
Nov 01, 2007 | Novelty 96512 Cuckoo Phone
Panasonic AG-185 Camcorder Logo
93 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
