Question about Gaggia Espresso De Luxe Espresso Machine
Gaggia Classic Espresso machine
I have a Gaggia Coffee. Recently it is > doing a poor job frothing milk. I replaced the steam > pipe and am using a saeco Pannarello wand.I also replaced the group gasket. The steam comes out enough to swirl the milk but not froth the milk. I Replaced the > steam pipe because I thought it might be Milk Stone. > I also descaled the machine twice. > > Anything I may have missed or can check ? > Could it be the boiler ? Thanks frother spurts, squirts in short intervals and heats up, but doesn't do a proper frothing job anymore. Flat whites instead of lattes and cappuccinos. Forther nozzle also leaks a bit of water when warming up No techie myself, so i don't want to take the whole thing apart before i know what could be the problem. Haven't descaled the machine in ages; could that be the problem? Marc
  • Simaky Sep 02, 2008
    hi,
    my problem got mixed up with someone else's....
    not sure what the solution is to my coffee problmes...
    here's the original post of the Gaggia problem we are experiencing:
    the frother splutters, squirts in short intervals and heats up, but doesn't do a proper frothing job anymore. pressure seems to come out in "machine gun bursts".
    Flat whites instead of lattes and cappuccinos. Frother nozzle also leaked a bit of water when warming up before, but doesn't do that anymore. since then, the frother malfunctions.
    No techie myself, so i don't want to take the whole thing apart before i know what could be the problem. Haven't descaled the machine in ages (done it recently, made no difference);
    hi,
    Scholar:
  • 73 Answers
The most common solution to this problem is to ensure that the inner piece of the frothing wand is properly in place.
otherwise This problem can occur if the metal filter basket in the portafilter is damaged around the edges, or if coffee has built-up on the edges. Ensure that your filter basket is clean around the edges, and if it is damaged, replace.
if the above solution is also not working then you may need to replace the steam valve. Please call tech department at 888-411-5282 so that they can thoroughly diagnose the problem and provide you with the appropriate solution.
Posted on Sep 16, 2008
  • 2,071 Answers
It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
Posted on Sep 02, 2008
  • 1,586 Answers
Sounds to me like there's a leaking gasket or joint somewhere in the frothing system. Your first bet is to check around the parts you replaced - did a gasket get squeezed or seated incorrectly? If so, it'll cause a pressure leak that will keep the frothing minimized. You'll still get the mixes (as you said) but they won't be frothed as they should because the pressure is leaking out along the way. Another idea would be to inspect the nozzle itself for a crack or damage - if that's the case, it'd cause the failure just the same as a leaking gasket could. Check around the parts you've replaced or adjusted first, since you know there was work performed, and that means there's always the chance that something was inadvertently missed, damaged, or (in the case of a gasket) not seated quite right.
Posted on Aug 27, 2008
  • 157 Answers
Its not heating up too much
  • 1 more comment
  • John Smith
    John Smith Aug 27, 2008
    the nozle may be blocked by some dry crust. I think its either blocked o the boiler isnt heating as much as it should
  • John Smith
    ya i think it needs a bit of descaling. A service for the maching would be good and will bring it back to tops
    Your on the right track my freind
  • John Smith
    when the nozzle is cracked or blocked, there isnt enough pressure to make any froth. SO that why its not functioning well
Lacks correct steam for milk froth
Requires cleanout and service,no quick fix
Jan 16, 2013 | Gaggia Classic Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
The steam wand emits a very thin and weak stream of steam making it impossible to froth milk. Should I descale the machine? If so, can I use spirit vinegar?
Decalcification of coffee machines boilers is better to be done with special powder for decalcification in aluminum. For making the solution from the powder you must go by instructions of manufacturer of powder. Anyway you should clean the pipe too, you get glass of water and put pipe in, steam up until it boils, than you live it for 3-4 hours. Softened milk sedimentation's will come out easily if they are present.
Feb 24, 2011 | Gaggia Baby Espresso Machine
Frothing attachment coming off from pressure
Check the holes in the attachment they might be blocked and the pressure of the steam is blowing it off.
Apr 14, 2010 | Gaggia Classic Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Gaggia Espresso De Luxe Espresso Machine Logo
216 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
