Question about HP Compaq Presario V2000 Notebook
Too bright screen
Need to dim my screen , when im in use of my laptop
    Brigadier General:
  • 5,158 Answers
Not knowing exactly what model it is. Look on the top row of keys on your keyboard. for what looks like a couple suns. At least on my compal that's what they are. Incidentally they happen to be on the up down arrow keys. May have to hold down the alt or control button to make it work. If you can't find it let us know the model.
Robert
Posted on Aug 27, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Computer screen dim
go to contol panel> power settings. Find screen brightness option for both "plugged in" and "battery". Turn the slider up all the way.
Jan 30, 2014 | HEWLETT-PACKARD ProBook 6550b XA673AW...
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Dim screen, bright mouse pointer
Right click the battery icon on the right bottom of the screen in the task bar. The performance profile may be set to energy saver causing monitor to dim to save energy.
Sep 09, 2009 | Gateway Computers & Internet
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 24, 2009 | Acer Aspire 5735 Notebook
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Compaq Presario V2000 Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
