Question about Kenmore 64902 Electric Dryer
Kenmore dryer timer doesnt move.
My dryer dial stopped advancing, so it would dry forever without stopping. Then awhile later, I noticed that it was no longer heating either. I think the first problem caused the 2nd problem. That is, I think it was left on too long and either the coils burnt out or the high limit thermostat was blown.
How do I approach this?
  • 2 more comments
  • eddie smith Aug 27, 2008
    What is the most likely cause of the dial not advancing?
  • eddie smith Sep 07, 2008
    Where is the timer unit located? Is it in the top of the dryer in the section where the dial is located?
  • eddie smith Sep 10, 2008
    As it turned out, the heating element was bad, not the t-stat. Also, the timer motor was bad. Thanks!
  • eddie smith Sep 15, 2008
    body {
    background: #FFFFFF;
    margin: 0px;
    padding: 4px;
    font-family: arial, verdana, sans-serif;
    font-size: 10pt;
    p {
    margin:0px;
    padding:0px;
    .spwrap
    background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
    Well, the t-stat may still be bad. I haven't actually fixed it yet. However,
    I do know for a fact that the heating element was bad because there is a break
    in the coils. (there was no conductivity so I examined it closely). It looks
    like it just got really old and burned through. (That's what it looks like to my
    untrained eye -- reminds me of a burned out light bulb -- the coils are all
    black, etc.)
    I'm waiting for the new timer to arrive in the mail before installing the new
    heating element.
  • 550 Answers
The timer contains a small electric constant speed motor, that advances the timer through its stages. the motor separately costs 1/2 as much as a new timer unit if you can buy it, your local parts guy may have rebuilt timer units for kenmore, popular brand.
partsselect.com or allaplicanceparts may have motors
and 2nd problem will be the hi limit thermal fuse, on the exhaoust duct internal to the dryer, small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this Kenmore dryer timer doesnt move. - 6138e08.jpg or like this 8b7e2d6.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or meter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
  • AlmostBob
    AlmostBob Sep 10, 2008
    Read your post congrats on the fix
    It is very rare for the alnico (ALuminium NIckel CObalt hi temperature alloy) heating coil to fail before the thermal fuse blows,
    unless the thermal fuse is bypassed, or been replaced with the wrong rating
    please examine the exhaust ducts inside the dryer and ensure that the thermal cutout has not been bypassed,
    It might just be bad luck, paranoia impels me to consider bad repairs.
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
The Timer Knob on my Maytag Dryer does not move. The drying just goes on and on unless I notice and stop the dryer.
While the dryer is turning slowly advance the timer knob to the end of the cycle. The dryer should stop. It sounds as if the timer motor has died or is not being powered for some reason and is not advancing the timer.
Nov 12, 2009 | Maytag Clothes Dryer Almond Timer Knob...
It wont stop running... dries perfectly but wont stop. Thanks! ;o)
either a timer or the heating element or a blocked vent also there is a resister on some kenmore/whirlpool dryers and if it is out it wont advance in the auto cycles. It should advance in the timed cycle with or without heat
May 11, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore dryer dial doesn't advance
That looks like a thermal shut off to protect the dryer if it overheats.
I am assuming that the timer never advances - even in timed mode (as opposed to some automatic drying setting).
Most likely you need to buy an inexpensive multimeter and start testing. There should be a schematic on the back of the dryer either on the outside or on the inside of the back panel.
Since timers on dryers are just mechanical devices that use a small motor (and yours is brand new), it looks like your timer is not getting power. The switch itself is mechanical, you should be able to rotate it to the different settings, press the start button and the dryer will work in the correct mode. Without electricity, the timer won't advance.
Check for loose or burned connections. Dryers use a lot of amperage so occasionally the wires can get burnt and corroded.
Sep 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Kenmore 64902 Electric Dryer Logo
482 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
