Cleaning the thermal grease and doing a trick with few pennies doesn't solve anything, the problem is that the soder between the Cpu / gpu and the mainboard melted during overheating and is not making the proper contacts the only way for you to fix it at home is to overheat the console again with the heatsinks loosened a bit so the components have room to move a millimeter or less to the right position and the console will work again. If not, read the secondary error code by pressing the controller reconnect button down together with the eject disc button, the flashing code will change, write down how many leds are flashing, then press the buttons again, and write down how many are flashing, repeat 3-4 times until your back into the "Red right of death". Tell me code you got, for example 4422 (4 digits)
Go here ->http://www.xboxredringofdeath.com/ but for me the bvest option is to send the device to a shop.
