Emerson LC320EM82S 32' LCD TV won't stay turned on. Immediately shuts down.
  • 7 more comments
  • Anonymous Feb 01, 2009
    same model same problem
  • littlejoe444 Mar 18, 2009
    emerson lc320em82s, setcomes for second or two thencuts off.
  • CAL178 Mar 19, 2009
    THE SET COMES ON FOR A SECOND THEN SHUTS DOWN
  • Anonymous Mar 31, 2009
    me to
  • alysue98 Apr 12, 2009
    Power to the tv unit but when hitting the power button, power light turns green then turns off. Screen does not come on. Set only 1 year old.
  • Pachito Apr 16, 2009
    The set Comes on for a Second Then Shuts off
  • okcchemist Apr 24, 2009
    Excellent for ud DIYers. Thanks!
    Glenn
    What is the price for the board and where can one order it?
  • Devon Sacco
    Devon Sacco May 11, 2010
    Do you guys still need help with this problem? I do have answers
These have bad inverter boards, the part number is: 1FSA10164 for the MUT cba which includes the inverter board. The boards have about ten plugs and 8 screws after you get the back off.
Posted on Apr 08, 2009
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Emerson LC320EM82S Unit works ok with manual buttons at top of set but Emerson remote and after market remotes wont work at all
Hello
The remote sensor inside the front panel of your TV is faulty. This is a three terminal device, can be located just behind the infrared window at the front panel of your TV. You have to open your TV, and unscrew out the front panel circuit board to access it.
Sep 05, 2011 | Emerson LC320EM8 32 in. LCD TV
I cannot find a code to code a 32" Flat Emerson TV to Charter remote UR4U-MDVR-CHD2. Do you have a solution?
Try this option....
Turn your TV on.
Hold down the TV and OK/SEL at the same time until the TV button lights up and then release the buttons. The TV light should stay solid at this time.
Next, press the channel up button. If the TV turns off then press the TV button again to lock in the code.
If the TV does not shut off then continue to tap the channel up slowly until the TV turns off. Once the TV turns off then press the TV button to lock in the code.
**** Note this process may take a couple minutes to cycle through all the codes to find your TV ****
Good Luck and please rate this solution....
Jan 06, 2010 | Emerson LC320EM8 32 in. LCD TV
Hi, My set is 9 months old. When I turn it on, it stays on for a second, and then shuts down.
go to topselectronic.com and send it in for service they do great work there and fast
Sep 28, 2009 | Emerson LC320EM8 32 in. LCD TV
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
No power. Won' come on. Model number DS35580.
model number lc320em82s...emerson tv...wont turn on
Aug 15, 2009 | Sanyo Televison & Video
LCD TV SHUTS OFF AFTER FEW SECONDS MODEL LC320EM82S
You can purchase the part itself.
The part # for the Inverter Transformer is LTZ2PC0MS008.
I just look on the web and nobody has them in stock right now.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
Right now, Shopjimmy.com has the whole board in stock. (6-06-09 1:55pm @ California time)
http://www.shopjimmy.com/catalogsearch/result/?q=BA71F0F01042
Jun 06, 2009 | Emerson LC320EM8 32 in. LCD TV
Emerson lc320em82s need help checking inverters
OK,
1. On the power inverter board unplug all 6 wires that go to the LCD screen.
2. Test each of those ports for resistance.( the one without the resistance is the bad one.)
3. Or, test each port for Voltage output ( this will happen very briefly since the TV will turn itself off automatically).( The one without voltage will be the bad one).
Mar 21, 2009 | Emerson LC320EM8 32 in. LCD TV
Televison & Video Logo
1,193 people viewed this question
Top Televison & Video Experts
