Question about Casio Cassiopeia EM-500 Pocket PC
EM-500 memory question (new user)
I just want to ask a quick question about MMC cards for my EM-500. Do I have to purchase MMC cards only made by Casio? Or, can I purchase a Crucial MMC card from Newegg?
    Master:
  • 551 Answers
With the update 1.04 for the em500, secure digital (sd) cards can also be used. I use a Viking Components 64mb MMC card and a SimpleTech 128mb SD card.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
I have successfully used MMC cards from SanDisk, Toshiba, Kodak and PQI in my EM-500. Maximum size I've tried is 64 MB - within the specs. If you want to risk and try a larger memory, buy it from a retailer so you can return it if not supported.
    Master:
  • 551 Answers
You can use any brand whatsoever. If you are concerned about compatibility - a genuine problem with some manufacturers - you might consider buying from a retail outlet & test it out on the device itself. Casio uses either Toshiba or Hitachi cards so that would be your best bet.
SOURCE:
HOw to format memory card , whenever i restart my phone , It ask me to format memory card, but i donoy know the code Please help me How to format even i have format from PC and did Master Reset from...
If that would be your case that the phone is always asking you to format the MMC, your MMC could have been damaged or getting into being corrupted, please try using another MMC, and reformat it, then re-boot the phone, see if that works.
If that works(your other MMC) it simply means that your MMC is corrupted or faulty, have it replaced (buy a new one)
Sep 20, 2010 | Sony Ericsson K530i Cellular Phone
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
Mmc is not detected in the phone (it says "mmc is corrupted" ) though it opens in pc. I hav formatted it with fat option (hard format and not Quick format).other mmc if inserted show the same problem....
Try to read your memory card with your computer, use memory card reader, if problem same. it's say mmc corrupted, need to format also, that mean your memory card damage already.
Jun 24, 2010 | Nokia 3230
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN (sajwhat_2003@yahoo.com)
May 05, 2008 | Motorola Mobility RAZR V3
Nokia 6288 / format memory card
MMC puchased should be formatted once, because new MMC comes with file system FAT-32. and mobile phones supports FAT file system. You can copy your data from MMC to PC using MMC reader/writer first. Then format it in your mobile and then reload your data in formatted MMC at folder created during formatting. Then you may see your MMC working properly. Fix your problem and vote here to fixya for solution....
Jan 09, 2008 | Nokia 6288 Cellular Phone
Cant save to 128mb mmc
I can save successfully from my E-115 to my 128mb card. I have Flash Format installed, which indicates the following settings: Heads: 16; Cylinders: 948; Type: FAT16; Sector Size:512 Bytes; Cluster Size: 2kb. Are you using Flash Format?
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
MMC/SD Cards
In most cases they are interchangeable except for the security feature which you don't need for storage on your EM-500. SD cards are faster in read write department as also they cost more due to security featurtes built in. In Casio cameras Casio recommends SD cards but I have been using MMC cards very successfully.
128meg MMC for Casio Em-500
Did you put your mp3 files in the my documents folder on the mmc? because if you place it anywhere else other than my documents the won't play (thanks microsoft). Also, the mp3 files might need conversion in order to actually play. It happend to me also, the files on the mmc would play on my siemens sl45 phone but on the em-500 not, until i use the sl45 connected to my computer to transfer files to the mmc than play with em-500.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM-500 music transfer
Seeing that you are using a EM500 with only 16mb of RAM, you might want to get a SD/MMC Card. With that being said, let's do this, shall we? Connect your PPC to your desktop using ActiveSync, then press on the TAB "Explore" then "My Pocket PC". You are interest in the "My Documents" folder, that is where you will place your .WMA, MP3, OGG files. Just copy the music file from your desktop that you want on your PPC, and then paste it to the "My Documents" folder of your PPC. Now if you have a storage card (MMC/SD), you will have to create a folder on the storage card and name it to "My Documents". So you will then have 2 My Documents folders, one on storage card, and 1 on the PPC. If you want the Music file on the storage card to save space on your PPC, then do the following. Connect the PPC to your desktop using activesync, then press on the TAB "Explore" then "My Pocket PC". You then need to click on the "Storage Card" folder, there you will see your "My Documents" folder you created. Just copy the music file from your desktop that you want on your PPC, then paste it to that folder. To speed things up, you can also use a MMC/SD Reader. you can then copy and paste directly on the memory card, without going thru ActiveSync. Goodluck, and have fun!
Programs to MMC?
Can you access the MMC from the desktop ? If yes - you could copy the installation cab files to the MMC card externally & then simply run the file on the MMC for the application to install. There have been some issues with the pcb design of the EM-500 cradle & Casio has updated the design with some aditional componets which should sort out your connectivity problems. Hope this helps.
Casio Cassiopeia EM-500 Pocket PC Logo
146 people viewed this question
Top Casio Computers & Internet Experts
k24674
Joseph Hoffmann
Joaquim Martins
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
