Distorted picture What specific controls should I use and what adjustments should I make. Imagine having a photograph in your hand between your thumb and ring finer. Now take that photo and bend it in a concave fashion. The photo distorts when it bends. The picutre on my television is the same way. The stock market ticker flows across the screen in an arc. Am I giving you an accurate description of what is happening?
    Master:
  • 763 Answers
Every monitors(almost latest) or crt or lcd got a pincushion an adjustment of bending of the screen to become look like a semi 3d. try to adjust that and see what happen. if still persist then you might send that to a technician to replace some parts(if the hardware is the problem). by the waty it must have a default control for that and after press the degauss to refresh the screen.
Posted on Aug 27, 2008
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
I have an HP 2009m monitor. When I try to have
The problem is that your picture is not of high enough resolution. You need to get a higher resolution picture. There is nothing wrong with the monitor. The picture is distorted because the picture does not contain enough photographic data to scale to the size you are stretching it to. Higher resolution = larger picture without distortion.
Jan 03, 2010 | HP 2009M Monitor
My photographs are distorted on my widescreen, how do I rectify?
go into the settings menu for the monitor, properties settings display, and change the resolution to the native resoultion for your monitor, iyt sounds like you arend running it at the proper resolution, also run the driver that came with or is on the website that is associated with this specific monitor, it sounds like it was never set up right
Jan 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
Aspire 5050 laptop monitor displays red sand like appearance
It sounds like a resolution problem which you can fix your self just right click personolise or properties then set your coulours to as high as it will go. Then set you resolution to high.
if you have any questions please dont hesitate to ask
Nov 23, 2008 | Acer Aspire 5050-3242 Notebook
I cant read the scroll on the bottom of the screen
You don't give a model number or age of the set so I can't be too specific, but there is an adjustment for picture size (it's actually termed "vertical height") in TV sets. Many newer sets make adjustments through a service menu using the remote control, but many sets have a physical adjustment control inside. I can't tell you how it is in your set, but you can take the back off and look at the circuit board. If you see a small round adjustment control (screwdriver slot for turning) marked "vertical size," "height," "vh" or something similar, that's the one. A little turn one way or the other will do the trick.
Now having said all that, it's also possible there may be bad capacitors in the set's vertical circuit. Is this a problem that just started, or that's gotten worse over time? Do you notice distortion at the top of the picture, like a person's head or other round object looking stretched out if it's at the top of the screen? If so, that's usually a sign of capacitor failure. There are a few in the vertical circuit, usually in the range of 1 to 10 mfd at 50 volts, and they commonly go bad with age. Without knowing what model TV you have I can't suggest specific part numbers.
Hope this helps or gives you a start.
Nov 19, 2008 | Televison & Video
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Viewer only shows distorted black and purple image.
Hi, I have exact same problem. This problem started when I used Energizer alkaline batteries first time instead of rechargeable batteries. It looks like CCD problem, but dont know how to fix it. Zahid
Nov 14, 2006 | Canon PowerShot A70 Digital Camera
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
