Question about RIM BlackBerry Pearl 8100
Ringer Volume Is there a way to adjust the ringer volume other than the loud icon? It is hard to here it while it is in the case.
  • RIM Master
  • 1,800 Answers
Get to the settings/sounds/volumr/
increase it
plz rate this post!!
Posted on Aug 27, 2008
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
Jul 19, 2010 | Panasonic (KX-TG1032S) Phone
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Backberry 7290 Ringer Volume
Click the PROFILES icon and set the unti to LOUD :)
Feb 06, 2008 | RIM BlackBerry 7290
How is ringer volume adjusted?
the ringer is too loud and the beeps from pressing the buttons are too loud.
Dec 30, 2007 | GE 25932 Cordless Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
RIM BlackBerry  Pearl  8100 Logo
80 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
