Question about Zoom X5 5654 DSL Modem (DH5654)
Problem with zoom configuration
Is the default gayteway of zoom 10.0.0.2?
  • migzzz Aug 27, 2008
    what other default gatewat does zoom have?
Configration lan for connection
Posted on Sep 16, 2008
  • lar77 Sep 16, 2008
    create a new lan configuration in my laptop
Doesnt show all four quadrants
Reset the calculator to its default configuration or set the Zoom to Standard. You can also set the windows dimensions to be Xmin=-10, Xmax=10, Ymin=-10, Ymax=10.
Oct 10, 2012 | Texas Instruments TI-84 PLUS Graphic...
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
My TI-53 calculator will not graph all it says is ERR: window range
I do not know of any TI calculator with Model number 53, but I will try to give a general answer. If you get a window range error that means that the Window limits are not set correctly. For example, the lower limit in X, Xmin must be algebraically smaller that the upper limit, Xmax. The default for the TI graphing calculators are Xmin=-10, and Xmax=10. Similarly the Ymin must be smaller than Ymax. The default limits for the y-variable are Ymin=-10, and Ymax=10. If your calculator has a Zoom function ( if it is a graphing calculator, it must have it) then Press Zoom key and select Zoom Standard or ZoomStd.
Jul 16, 2011 | Texas Instruments TI-89 Calculator
I need to configure the Zoom 4402 as a gateway/router.
Can you be more specific with your requirements?
Here is the Manual: http://www.zoom.com/documentation/wireless_n/4402_UserManual_Eng.pdf
Normally you like to have following setup (in most cases the default operating mode) PC - ZOOM lan - ZOOM wan - Internet
(you don't have physical port for the ZOOM lan, but it's easier to think there is.)
Here ZOOM operates as a gateway for computers in lan (it can also work as dhcp and dns server)
Basic network would be something like this: http://img.askleomedia.com/network.png
If you provide more detailed requirements I can give you better solution for your problem.
Mar 10, 2011 | Samson Technology Zoom 4402 Wireless...
Graphing Problems
In home folder (main calculator screen) press [Diamond][F2:Window]] to access Window configuration screen.
Press [F1] ( not mecessary now because the F1 page is open by default). In the F1 page of configuration screen set Xmin=-10,
Xmax=10
Ymin=-10
Ymax=10
Xscale=1.
Yscale=1.
OR
Press [Diamond][F2:Window][F2][6:ZoomStd] (Zoom Standard) to set all values as above.
If a graph is active (axes displayed, or part of a curve is showing) press [F2:Zoom][6:ZoomStd]
Feb 15, 2010 | Texas Instruments TI-89 Calculator
After installing the router it was working fine. I went in to set up wireless security and now the internet light stays red.
Probably means that the security is turned on, if the wireless doesn't work even after you have entered the right password then press and hold the reset button on the back of the router to restore it to defaults - factory defaults just like it was first powered on.
Oct 07, 2009 | Zoom X6 Adsl Modem/router Rohs...
Lost user name and password for configuration manager
You ADSL Modem's default username is admin and password is zoomadsl, If you have changed before you can reset the the device so default username and password will work. for further information you can check link below
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
Mar 22, 2009 | Zoom X6 Adsl Modem/router Rohs...
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
I just bought a wireless HP printer. I have followed the instructions to configure it, but I do not know the WPA or WEP of my Zoom Router. How do I find this and what do I do with it? My wireless printer...
Open your web browser and enter the Internal IP address of your router (usually 192.168.1.1 - You can check this by opening a command prompt and type in ipconfig. The router's IP will be your gateway address).
You will be prompted for your routers username and password authentication. It probably still is the default of the device. It depends on the device on what default password it will be. The best way to find out what the username and password is to look in the owners manual. If you don't have that, then google the model number of your Zoom router with the words "default password".
Once you are in your routers web page, click on the Wireless icon at the top. This page will show you everything you need to configure your HP wireless printer.
Jan 26, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Configuring ppoe connection with zoom modem
Your external (WAN) IP should be set to DHCP for most ISP's. Your internal IP will be the default gateway for everything in your LAN to get sent to. If you can log into the zoom with your browser, try that IP address for your gateway. If not can you let me know some more details on your zoom model.
Aug 02, 2007 | Zoom (56600000) DSL Modem
Zoom X5 5654 DSL Modem (DH5654) Logo
463 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
