Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
No recognized by any PC I try to plug in
HI, I have this Acomdata 320 GB HD more than 1 year. Everything was fine. I loaded alot of photos and music in that HD. A few days ago, I try to plug it to my new PC with Vista. It didn't show up in Device Manager and My computer. Then I plugged to my old PC XP, nothing showed up either. I plug and unplug HD while computers are off (of course). When HD is turn on with the blue light, it seems to me it doesn't process anything.
1- What can i do to make it recognized by PC again?
2- if not, what can i do to recover all the files (photos and music) from HD (I want to do it myself)?
Thank you very much for your advice.
Landry HI I HAVE A SIMILAR PROBLEM I ONLY MOVED MY COMPUTER TO A DIFF LOC IN THE SAME HOUSE AND THE HD DOSNT RECONICE IT . tHE BLUE LIGHT IS ON THE ALL THE TIME AND DOSNT EVEN TURN OFF W THE SWITCH ON THE BACK OF MY HD> CAN SOME ONE PLEASE HELP ME?
    Sergeant:
  • 369 Answers
Hi are u sure the hard disk was not complitly full if yes try to use anothe backup software such as easy recover pro or so and copy all the data from your hdd to another location but befor udo so please be sure
1. shut down your system shut down the hdd plug the power properly to your hdd and connect the usb or firewire then connect the medium to your system and start the hdd and then start your system ...if it detected its fine...
2. if still dosent detect check in disk management by right clicking on my computer icon go to manage and then disk management if u see the hdd over there and showing status a forigen just right click on the word and say import forigen disk .and should work
if the status shows unalocated right click on it and say intialize hdd ..
if shows helthy and be sure have a drive letter on if not then please right click on the hdd strap and say add or change drive letter and use any abailable drive letter
thanks
good luck
Posted on Jan 04, 2009
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Computer won't recognize drive. Plugged in. I'm using windows xp. It shows up in device manager, but with a yellow check indicating a problem. Any ideas?
Hi yes you will need to down load and install the latest driver for this device; do a google search for the appropriate driver. Hope this helps?
Jul 04, 2010 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Not recognized
Th prob lem could be most probably your hard drive casing not supplying the correct voltage and not enough for the hard disk to spin the moter so please connect the hd directly to the computer if its fine just change the external casing..
good luck
Jan 04, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Nov 02, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Wont recognize drive
Aug 19, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata drive not recognized
the drive may have failed..... they can often be "fixed" long enough to retrieve data. i make alot of money from failed maxtor hard drives.
Robert
Jul 12, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Hard Drive doesn't show up
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
I was just having the same problem... but someone I connected it to my computer, forgot it was connected, and when i got back everything was back again (needless to say i got another 500GB HD from another company and back up the first 500gb).
But if that didn't work, i was going to take the drive out and connect it as a slave to my computers MB, back it up, reformat it, and then put it back in the enclosure to see if it works again (at least i have my data).
$500 bucks?!?!? Shoot, send it to me and i'll do it for $299 (that includes a Western Digital 500gb External =)
Hopes this helps.
Dec 06, 2007 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
192 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
