Question about Panasonic AG-185 Camcorder
Transferring analog to DVD
I am a digital camcorder novice, don't own one yet, but am leaning towards Canon Elura 65. Just wondering how dificult it is to transfer old analog tapes to a DVD. Is it fairly easy with the right software or no? Thanks.
    Master:
  • 473 Answers
Except the unit is optimized for its job, and does a much better job of capture than seperate parts are likely to produce. I have lots of different capture options available to me including ATI AIW and conversion via firewire and a digital camcorder into Sony's Vegas 5. I have been impressed with the quality of the captured video coming from the HP unit. It's also a no brainer, get it done approach. You do not have to learn the details of capture, render, burn, etc., and you can start the conversion of a tape and walk away or go to sleep. When you come back, the job is done. It also gives you a dual layer burner which is not run of the mill, and the software knows how to use the dual layer capability. That means twice the capacity of a normal DVD burner. I'm getting VHS conversion done that I have put off for years because I hadn't gotten around to doing it with more time consuming approaches.
Posted on Sep 06, 2005
    Master:
  • 473 Answers
Analog video to DVD HP DC5000 is a DVD Burner with a capture card inside, at their proper price. I would rather suggest to have one capture card (when you already have a DVD burner) rather than ending up in having two DVD burners plus a capture card in total.
    Master:
  • 473 Answers
Your ten year old Panasonic camcorder? If so, I sure hope the camcorder has some way to send the audio/video on its tapes to an external device. If so, you can use the HP dc5000 to covert your tapes. It will capture the tape contents, and burn it to DVD without very little required from you. It does need to be connected to a computer when it operates, but requires no special knowledge on your part. It will burn the DVD, and, optionally, save a copy of the video on your harddrive if you wish to edit. It can also serve as an external DVD/CD burner when not engaged in video conversion activity.
    Master:
  • 473 Answers
I envisage two options for you: 1. Install a video capture card in your pc. Choose one that has ports that match your analog camcorder ports. Best option: Separate capturing using S-video + a separate audio connection. Common and simpler option: Campture "composite" video using one video + one audio jacks. You don't need a new camera to make DVDs from your analog tapes. 2. Buy a pass-through (must be this type, not all digital cameras have this function!) digital camera. Connection and flow: analog camera (or your analog VHS VCR)to digital camera (via RCA cables); digital camera to pc (preferably using Firewire)- all simultaneously. Here, the digital camera will perform the function of a capture card. You will certainly need a software to capture via capture card/pass-through digital camera to your pc hard disc. Your captured video on pc can be initially in AVI/ DV AVI(better options to edit) and then convert to MPEG2 (DVD) format, or directly in mpeg format (with poor editability). Frame size (capture resolutions) should be as big as possible. In any case you will need some basic knowledge on digital video, capturing, and editing. And all the nitty-gritty that you will need to know can be found somewhere like "Digital Video Primer" and "DVD Primer".
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Would like to know how to copy mini tape to a DVD
You'll need an IEEE 1394(firewire) for taking instant video to the puta, then the DVD. You always have to save it on your puta first as a wma, avi or other type of flie before transferring it to the dvd burner. If you don't require instant gratification you can use the AV/AD out to USB cord that came with the cam. A Firewire cost around $60 for a 5 footer.
Aug 17, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Download movie to computer
I have an elura 65 and I believe this model does not let you download your movies onto the computer in full motion. you can only do it through quicktime or some other similar program using less frames. the higher models: elura 70 etc. are supposed to be capable of transferring full motion film. that's what I understood from the owners manual. hope this helps
Jun 09, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Moving photos from pc to Elura 65 camcorder memory card
You can buy both internal and external USB card readers that can read just about any card you can think of in a package about 3" square. They are not expensive either.
Your local PC retailer will (read should) have these in stock.
Hope that helps
Apr 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
Hi There, Did you get any resolution for this problem? Even I have the same problem with my canon elura 70. Pls. share your thoughts. Thanks... Pradeep
Feb 08, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Panasonic AG-185 Camcorder Logo
171 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
