Question about HP LaserJet 1010 Printer
Modos operandis After printing the printer torn the paper
    Master:
  • 479 Answers
Servicing required and the tefllon inside the printer needs to be replaced .it will cost u near to $25
if the tefflon is replaced.only servicing not more then $10.
Posted on Oct 01, 2008
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Printer jammed and paper was removed but now it says paper jam and won't print from a command from the computer
hi go into control panel find printer settings u will have to clear any printing commands in c whats printing........good luck
Sep 04, 2015 | HP PSC 1315 All-In-One InkJet Printer
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
Printer D2460 blinks not print
The HP printer may print incomplete characters. This issue occurs due to clogging of print heads. So this problem can be solved by cleaning or replacing the print heads. Sometimes the printer will not accept the paper tray. At that time, you have to turn off your printer and disconnect the printer from its power source and reconnect the power and then turn the printer on. The printed pages will sometimes come out skewed, this may be due to curled or torn paper become jammed inside the printer. One easy remedy for this problem is that, you have to remove the torn pages from the paper tray and smooth down all the curled edges of the paper. If the settings of the printer are not correct or the paper tray is overloaded, the printer may pick multiple pages for printing, which could result in paper jam.
Get more help to fix HP Printer Not Printing error. Hope this helps you.
Jul 04, 2011 | HP Deskjet 2460 InkJet Printer
Paper goes scew whiff when trying to print. Says there is a paper jam but none visible.
Smaller torn bits of paper may still be in the printer. Unplug the power, open the back access panel. Look for torn or jammed paper. Also check the ADF (auto document feeder) for a jam.
When you try it again, Dell recommends that you fan your paper. Fanning the paper helps break apart the bonds left by improperly cut paper which leaves the edges of the sheets interlocked.
Dec 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Paper jam in tray
Chances are the paper is getting torn as you remove the tray. I suspect you need to replace you feed rollers.
Feb 20, 2009 | HP LaserJet 4600dn Color Printer
PRINTING IS SMEARY AND NOISY
If there is a clicking noise as the printer is printing then most likely the fuser film has torn. The fuser film is part of the fuser unit. This item is best replaced by a technician.
Have you found pieces of film like material around the printer paper exit? It is most likely a dark grey color.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
Fedd paper and paper jam
The paper used for printing should not be wet, torn or folded from any side as this can cause paper jam, hence resulting in carriage jam. Also, use only one type of paper at a time while printing. The paper should be added to the In-tray only when the printer is not in use. Make sure not to overfill the In-tray.get more information
http://h30434.www3.hp.com/t5/Other-printing-questions/Printer-Paper-Jam/m-p/126558
Jul 01, 2008 | Office Equipment & Supplies
Epson 1280 Will Not Take Paper through to print?
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Attempt printing.
Apr 19, 2008 | Epson Stylus Photo 1280 InkJet Printer
Paper jam in 1120 hp printer
Hi there, Try printing again using heavier paper. Board types will likely push the torn papers out. Hope this solves your problem.
Sep 17, 2007 | HP DeskJet 1120cse InkJet Printer
HP LaserJet 1010 Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
