Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor Problem When I push th power switch, the green light won't come on
  • rakesh_02jun Aug 27, 2008
    i have the same problem
  • hunglouis Sep 03, 2008
    monitor 753dfx, switch on : no picture, no green light, Pin 3 of DP904C is 11 - 12v DC.
  • 20 Answers
First check the power switch with a multimeter,if its correct then check the power supply part of the monitor circuit. If you are having any problem with that part change the FET with another.
Posted on Sep 21, 2008
1.check power cord
2.check power supply
3.make sure uP controller circuit and its related components and power
ps: I suggest to u that was more detail for submit problem.
Thank you,
paragu7
Posted on Sep 18, 2008
2 Suggested Answers
SOURCE: Monitor Problem
The power is for the monitor to work
Posted on Apr 05, 2009
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Jan 15, 2012 | Pyle Car Audio & Video
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
Monitor Problem
its a power prblem
u need to change the internal power conector
Sep 03, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Monitor won't come on
Check the power cable of the monitor make sure everything is properly connected.
May 10, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
171 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
