Question about GE Refrigerators
Ice maker in GE GSS25QSWSS led light is on. Won't make ice. There was tons of ice everywhere. I defrosted it all, but light remains on even if I switch it off for a while. Comes back on immediately when I turn the ice maker back on.
SOURCE: Defrost problem on GE TFX22ZR
i changed the motherboard heating element and the sensor and it still freezes please help my email is mjeffries@philadefender.org thanks
Posted on Aug 03, 2008
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
aasc
  • 1606 Answers
SOURCE: GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: seee note on ice maker stopped working, blinking red light
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
rtwywy
Posted on Sep 30, 2010
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
Why would my GE (model # TBX18SA) just stop making ice?
Is there any ice remaining in the slots of the ice maker? If not then the water control valve will need to be replaced. If the ice maker still has ice in the cube slots and does nothing then it is the ice maker that needs to be replaced. Here is the=> WR30X10093 Ice Maker for your TBX18SA and the=> WR57X10033 Water Inlet Valve
APPLIANCE 911
Mar 15, 2016 | GE Refrigerators
How to troubleshoot ice maker for my GE refrigerator
The first thing to check is the temperature in the freezer. Even though everything is frozen the ice maker won't cycle unless its below 10 degrees F as a safety precaution. If the temperature is good, and since you can't manually advanve the ice maker, or not suppose to anyway what I would do is turn the ice maker off a few minutes and then turn it back on, but when you do pay close attention to the fill tube where the water comes in at, because if the valve is good, a little water should flow up real quickly. If this happens, change the icemaker.
May 10, 2012 | GE GSL25JFPBS Side by Side Refrigerator
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
Nov 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The heater remain on and the motor does not move
iis this the ice maker heater or refrig. defrost heater if ice maker need new ice maker.
Sep 08, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Refrigerators Logo
276 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
