Question about HP Pavilion dv4000 Notebook
Pavillion wont work with battery
Hey i have a Hp Pavillion ze5700 and the battery charges when i take it out it says full all the lights turn on the, but the laptop wont turn on with the battery alone only works with the charger and when i plug the charger in it showes that the battery is fully charged. what can be the problem
  • mike_d214 Sep 18, 2008
    Mine won't recognize that a battery is even there (in performance and maintentence power options). What going on!?!
  • 186 Answers
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Posted on Nov 18, 2008
Why wont my hp pavillion dv7-1240us turn on with or without being plugged in ? but while plugged in if i hit the power button all the upper lights breifly come on then off..
because the battery isnt charging. Most likely cause is your dc jack is broken. Take out the battery, plug in AC adapter. Gently wiggle the adapter and hit the power repeatly. If it briefly turns on and off then yes your DC jack needs to be re-soldered.
Aug 16, 2012 | HP Pavilion dv7-1245dx Notebook
HP Pavillion ze5700 laptop wont start up
Hi, seems to be a wellknown problem of Pavillon NB's. Looks like that the northbridge chip on the mainboard ist unsoldered. Even if somebody tells you do fix it by dropping the mainboard into your baking oven for a few minutes, don't try it! There are specialists who have the technical equipment and the knowledge to fix that problem. But in most cases it would not held a long time.
Hans
Sep 09, 2017 | Computers & Internet
Pavillion ze5700 media test failure blue screen can't load nothing
Sounds like a bad hard drive or maybe bad ram.I would look to the hard drive first though.
Oct 08, 2011 | HP Pavilion dv9000z Notebook
I have an hp compaq 6720s and my charge port light blinks rapidly, it wont let me charge my battery and the computer wont turn on when the battery is full any thoughts?
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Mar 24, 2011 | HP Compaq 6720s Notebook
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My red xbox 360 controller wont charge with the included play and charge kit after i turn off my console, it works if i do it as soon as it dies but not if ive played for a little while and then turn it...
Basically an xbox battery has a built in 'memory' that it tells the xbox how much charge is in it and the problem with rechargable batteries is that if they're not used for a while and left at room temperature their charge begins to dissipate so when you plug it in the battery 'thinks' it's charged and tells the xbox the same when in truth it's not. What to do is keep plugging and unplugging the charger on top (waiting until the light comes on) until the charger light stays red (as opposed to going red then immediately green) the small amounts of charge put in each time will eventually give the battery enough juice to clue it as to just how much power it REALLY has in and will then start charging as normal.
Apr 25, 2009 | Microsoft Xbox 360 Controller
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Electrical fault
some times is because the prossesor is overheating that is one or try to remove all memory cards and try again then put one back try again
Dec 31, 2007 | HP Pavilion DV4015cl Notebook
HP Pavilion dv4000 Notebook Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
