Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
How do you replace the caron brushes on a Bosch washer/
  • Bosch Master
  • 3,463 Answers
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Posted on Feb 11, 2009
I have a Bosch Nexxt 100 Series WFMC1001UC/05 Front Load Washer that the brushes in the motor are wearing out. Were can I buy a set of brushes at? Any information would be helpful.
Part number is 154740 around 36 dollars from http://automaticappliance.com/ How to video from YouTube http://www.youtube.com/watch?v=N_r8d93xPYw&feature=youtube_gdata_player Different model washer but same motor. Look up videos for how to replace the belt if you have trouble. Symptoms of worn brushes include weak or no spinning.
Aug 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
WHERE ARE THE BRUSHES FOR BOSCH EXCEL 1400 EXPRESS, ARE THEY SEALED IN THE MOTOR .CAN YOU REPLACE THE BRUSHES OR DO YOU HAVE TO BUY A NEW MOTOR?
Some of the motors Need A HALF motor which is the end section with brushes fitted, quite expesive if you can get brushes they are around 5 times cheaper if you check a parts website that will tell you which one u need...
Oct 01, 2009 | Bosch Exxcel WFO 2865 Front Load Washer
Wont drain
Check pump/ hoses for blockages etc. also could be caron brushes on motor
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fit the burshs in a bosch machine
Tilt washer sideways to gain access to motor. You will see brush holder modules (2 of them). Each has 2 screws holding it into place.as you remove one, replace it exactly the same way. Once installed, run machine. Cant explain how to embed brushes, so test full cycle without a load.
Sep 16, 2009 | Bosch Washing Machines
Replacing brushes
Remove rear panel of washer.
Undo 2 screws securing motor to tub.
Pull motor plug from terminal block.
With a screw driver, or similar, lever back motor, keeping hold of it , and remove motor.
Fit new brush.
Please rate my fixya solution.
Thankyou.
Jan 31, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
640 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
