Vidal Sassoon VSCL870 Hair Trimmer Logo
Posted on Jul 13, 2011
VSCL870 Hair Clipper: I removed blades for cleaning. I have the small lower cutter that connects to the driver. I have the larger cutter. And I have a white plastic piece, straight and thin, 1.25" long with .25" tabs on each end. I can't figure out where this goes. But every time I reassemble and try it, it sounds like a chain saw. Where does this plastic peice go? Thanks!
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
How do you adjust the blades so that the hair won't get caught in the Oster 76097-440?
take off the clipper blade cover. 1 phielphs head screew. metal plate is about 11/2 ins. by 1" metal chrome cover. clean all hair out. your clipper came with a small plastic tube of oil. 1 or 2 drops no more put on cutter. any house hold oil will work
2answers
Why my andis outliner not cutting
Try cleaning the head cutter below the main stem. Remove screws and clean old hairs in there, also lubricate.
Thanks
3helpful
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
3helpful
2answers
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
1helpful
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Top Vidal Sassoon Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
