Question about Sony KP-61V45 61" Rear Projection Television
Sony KP-61V45 61 in. Rear - to verift what board is the convergence board??
Which board is the Convergence board the one in the back with the STKxxx on them or a board in front of the unit ? How can I identify the board?
    Genius:
  • 2,920 Answers
The convergence board will be in the front of the unit
Posted on Aug 27, 2008
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510 picture swirls in the corners and is doubled
The tv have a problems known as a convergence problems,it dead.The tv have any colors lines R,G.B mis alignment,picture have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Sony KP-51WS510 51" Rear Projection...
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
I have a sony kp-51ws500 that the red is bowed across the screen.
If you are referring to the convergence ICs (STKxxx), then look in the area for fuses and/or low valued resistors that may be open.
Let me know what you find.
Dan
Mar 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
The picture is distorted. It appears as the picture is being drawn to the center of the screen.
This is a convergence problem. This can be either bad solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These are large black ICs attached to a heatsink.These should be marked STKxxx.
Keep me posted.
Dan
Sep 30, 2008 | Sony KP-65WS510 65" Rear Projection...
Convergence IC replacement
some have plastic clips that need to be pressed back to release the board. There should also be 6 screws holding the D board to its frame.
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
464 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
