Question about Acer Computers & Internet
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my computer. I have a acer aspire 510-2966.
  • spanky11 Aug 27, 2008
    I want to know why the amber light FLASHES and does not turn green after charging.
    Scholar:
  • 81 Answers
Hi spanky11,
Amber - usually means it's charging. Then, it turns green when it is fully charged.
Hope this helps and good luck.
Posted on Aug 27, 2008
  • 197 Answers
If it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
What does blinking orange light on the phone mean?
Solid amber light when the battery is being charged.
Flashing amber light when the remaining battery level reaches below 10% htc has had some problems with batteries,when charging, if you are getting the flashing amber light feel the back of the phone. if it is feeling hot you may have a bad battery. hope this helps.
Jan 23, 2010 | HTC Touch Cruise Smartphone
Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Computers & Internet Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
