Home | Gateway | 450ROG PC Notebook | Gateway 450rog Audio pro...
Gateway 450ROG PC Notebook
Problem for Gateway 450ROG PC Notebook
Gateway 450rog Audio problem
By deadburdock on Aug 27, 2008
Hey there everyone. I recently was given an older (2003) Gateway laptop computer, model 450ROG.
Now, I am no stranger to reformatting the hard drives, installing a fresh OS, and getting the drivers and hardware up and running. I have built manycomputers and have reformatted many different types of computer s.
I have a fresh install of Windows XP Profesional on the computer. I have the all of the drivers working except for the modem (which i wont install cause who uses a modem these days?) and the audio driver.
Now all the info I can find says that this laptop contains a Sigmatel® Soft Audio AC97 rev 2.3 codec (STAC9752). I have tried downloading the audio driver that is listed for this model laptop on the Gateway site. The new hardware wizard starts to install the drivers for the audio and the blue screen of death flashes real quick and the computer reboots, once windows is logged on, the hardware wizard tries again to install the audio and the entire process repeats.
I have tried downloading the AC97 drivers straight from the Realtek site as well as older versions that I have found. The only way the computer will work is to boot in safe mode and disable the Realtek ACA97 audio and restart. The computer seems to run fine with the audio disabled.
Anyone have any ideas?
Same Problem
Apr 11, 2009
-   Gateway is having issues with the sound drivers. I too have an issue where the sound plays but then goes to mute after a few seconds. It seems the sound level settings do not get saved or the system things that I am touching the sound touchpad at the top of the laptop when I am not.
I contacted Gateway and they told me I would have to ship the machine to them. UGH.
-   Guest
Sep 18, 2008
-   Amazing how your description matches mine. I have also reinstalled the laptop to all but sound. The same BSoD and rebooting. On the BSoD I did get to see it had to do with portcls.sys. There is a lot of info on the internet about that, but none helps. I have installed different versions of drivers for the AC97, with the same result BSoD. I just gave up. Hopefully Gateway will solve this driver issue or somebody passes by that has a solution.-   djwave28
Best Solution
posted on Jul 31, 2009
Very Helpful)
orvelltucker
Rank: Apprentice
Rating: 100%, 1 votes
I have just re-imaged a Gateway 450 ROG for a friend of mine on the website the audio driver is found (http://support.gateway.com/support/drivers/search.asp?st=pn&param=3501353) under the heading Sound Downloads. This unzips a list of files C:\cabs\9520522
Readme.txt
stac97(security catalog)
stac97(control panel extension)
stac97 (setup information)
stac97(system file)
1. From the Start menu, click Control Panel.
2. In Control Panel, click Performance and Maintenance.
3. In Performance and Maintenance, click the System icon.
4. In the System Properties dialog box, click the Hardware tab, and then click Device Manager.
5. In Device Manager, click the plus sign (+) next to Other Devices, and then double-click Multimedia Audio Controller.
6. In the Multimedia Audio Controller Properties dialog box, click the Driver tab, and then click Update Driver.
7. In the Hardware Update Wizard dialog box, click Install from a list or specific location (Advanced), and then click Next.
8. In the next dialog box, click Search for the best driver in these locations, and then click Include this location in the search.
9. In the text box, type: C:\CABS\9520522. Click Next.
10. Click Finish.
Now once installed sound only comes from using the headphone jack, the external speakers get a little sound if the volume is turned up to maximum.
Hope this helps
Orvell Tucker Jr.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 17, 2008
Somewhat Helpful)
frcs68
Rank: Wiz
Rating: 82%, 974 votes
as with all BSOD's it can be many things causing the problem, with this particular one i'd first try swopping the ram, if you have two sticks take one out then swop them over to attempt to find a faulty stick.
if that makes no difference then reseat all componants in the machine. try reinstalling IDE controlllers, channels and HDD drives (drivers), failing that i'd fdisk, format and reinstall windows.
this BSOD is generally caused by either a faulty memory module or faulty hard disk controller driver. remember a faulty memory module could be system RAM, video RAM or even CPU L1/L2 RAM.
if any of the memories stick is at fault, there will be a different error, when the memories sticks change slot.
Was this helpful?
Yes
No
Solution #3
posted on Oct 10, 2009
Not Rated)
randal_wi336
Rank: Apprentice
Rating: 0%, 0 votes
This info I read on the internet. Load the the drivers and especially the audio drivers after loading windows xp and before going to msft to update windows on the gateway laptops. He said some drivers and particularly the audio drivers will not load after upgrading windows.
Was this helpful?
Yes
No
Popular Solutions for Gateway 450ROG PC Notebook
Questions and Unsolved Problems for Gateway 450ROG PC Notebook
Do you recommend Gateway 450ROG PC Notebook?
Answer
Answer
I need instructions for replacing the fan on Gateway 450ROG notebook. The fan is dying, very noisy... (More)
Answer
What Controller and Channel is Drive C: (The First 8GB Drive) connected to? I have a gateway NV52...
Answer
When downloading a file with a PC and AOL, I first get Download Manager and save to a folder. Then a... (More)
Answer
Gateway 450ROG SN: 0031598515 powers up only intermitently after many attempts. I hear a single... (More)
Answer
gateway 450rog wireless switch located
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gateway 450ROG PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 446
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
