Question about Cuisinart Coffeemakers
How do I properly clean the coffee maker and then get the light to go off?
  • dsachvie Aug 29, 2008
    Thanks - got the light to go off - didn't realize I had to rinse twice when descaling...
  • 515 Answers
  1. Allow the unit to cool completely and unplug it before cleaning. use a sponge dampened with soapy water to clean the outside of the coffeemaker, then dry carefully.
  2. Open the reservoir cover and the filter compartment. Remove the coffee grinder lid, the grinder, the filter basket, its cover and the support.
  3. Wash the pieces along with the measure, the carafe and its lid in warm, soapy water, rinse thoroghly and dry. Then replace them in the unit.
  4. All these pieces are also dishwasher safe.
  5. Never pour water inte the unit when the grinder is not in place.
  6. Wipe the part under the filter basket and the heater plate with a damp cloth.
  7. Do not wipe the inside of the reservoir as this may leave fabric or paper residue.
  8. Do not use abrasive sponges or cleaning agents as these could damage the finish.
The reservoir cover may also be removed to facilitate cleaning.
Over time and through normal use, lime deposits will build up.
Scale can interfere with the fine mechanics and give the coffee a harsh, bitter taste. For reason, your coffeemaker should be descaled regularly to guarantee good coffee. The frequency of descaling depends on how hard the water is and how frequently you use the coffeemaker.
  • To descale, dilute 30cl white vinegar in 30cl water, pour the mixture into the reservoir and begin a brew cycle.
  • Then run two full cycles by filling the reservoir with water (but no coffee) to rinse the system.
Hope this will help you.
Posted on Aug 27, 2008
SOURCE: cleaning my coffee maker
can the carafe of the stainless steel coffee maker go in the dishwasher?
Posted on Apr 20, 2008
SOURCE: GE 169164 coffee maker problem
I bought the GE 169164 coffee maker from Walmart, I also got the cleaning problem, I found and downloaded the manual from this link Automatic clean function is explained in page 11. Fill reservoir with water, press cleaning light which is also a button for 3 seconds until it flashes and wait to cleaning to finish.
Posted on Sep 30, 2008
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
  • 8596 Answers
SOURCE: how do I clean my coffee maker
The manual suggest 1/3 part distilled white vinegar to 2/3 part water, but if you are experiencing a specific problem, I would switch to a 50/50 solution.
Posted on Mar 11, 2009
  • 8596 Answers
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Posted on Mar 14, 2009
Why won't my Saeco Odea Giro descale?
Might need some urn cleaner to do a proper job. Scale is dry chemicals that you want remove so use the proper cleaning agent.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
Clean light
The best bet is to contact the company on line and seek the instruction manual for that machine. Usually, the fix is in the back of the manual.
Mar 25, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
B40wont work properly
I have 2 Keurig coffee makers and have found that if you make sure the seal connecting to the water source and the bottom are tight and the lid is pushed down with the coffee in it, tight it reboots itself. Blinking lights should stop. Also I have found that if the filter needs cleaning sometimes that stops it. Keurig is really great at troubleshooting and replacing their struff call the 1800 # if you don't get results.
Jan 12, 2013 | Keurig B100 Coffee Maker
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Cleaning light came on and now, coffee pot will not work
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Will not brew
-Tha Mp3 Doctor
Sep 02, 2008 | Cuisinart DCC-1200 Coffee Maker
Self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Mar 01, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffeemakers Logo
164 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
