Question about RCA F36645 TV
Rca f36645 no picture, makes squealing noise when you plug it in the socket
    Scholar:
  • 92 Answers
A squealing noise generally indicates that there is something loading down the switching power supply. Generally a shorted component will do that. Without any other information it's hard to tell which circuit could be the culprit. It may even be a faulty power supply itself. Was there any problem prior to this condition? Any odd picture problems, shrinking etc. or sound issues, tuning issues?
Posted on Oct 06, 2008
2005 ford freestar will make a squealing noise then die starts back up then may or may not do it again
Check to make sure there aren't any vacuum leaks. Did this problem start after doing the plug and intake clean, or was you having that problem before too?
May 17, 2016 | Ford Cars & Trucks
Sony 32" tv makes a squealing noise, the picture goes to a horizontal line, then goes away with the squealing noise continuing. Turning it off and on again resets it temporarily.
The power supply regulator board should be checked. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 03, 2012 | Televison & Video
My inspiron mini 10 freezes, makes a loud squealing sound and can only be reset by removing the battery.
loud squealing sound and lockup in windows, without hearing the noise my best answer is 99 percent sign of hard drive going bad, advise backing up important data and pictures.
Nov 10, 2010 | Dell Inspiron Mini 10 Notebook
Picture has disappeared!
Ur high voltage is dead,the FBT,the flyback transformer is not transfer voltage.The big block of plastic with a red wire with a cap to the CRT(tv tube).That thing is dead.
Sep 28, 2009 | Televison & Video
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Hanns G 19" LCD monitor Screen Problem
D3mon,
Looking at the photo that you took... You've defintely got a damaged panel. My advised get a new one...saved you the headached and $$$....
Oct 10, 2008 | Hanns.G Corporation HU-196DP LCD Monitor
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
RCA F36645 TV Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
