FINDING A PART FOR A DVD RECORDER DMR HS2PP
I have a Panasonic DMR HS2 dvd recorder which
did work fine except when the dvd holding unit would get stuck and after when times of taking it apart I accidentally tore the about 2 1/2
inch ribbon cable that connects the dvd drive
board to the rest of the unit. I need to replace this ribbon
cable .How does a electronics illiterate person look for num-
bers on the unit ? Some parts have specific numbers but
these connectors have nothing written on them as far as I can see.
Is it a flat 40 contact (Zif cable) Panasonic uses those in a lot of their products?
http://www.sourcingmap.com/zif-micro-ide-hdd-adapter-converter-p-32516.html
Posted on Nov 25, 2009
    Problem Solver:
I got no help. I just gave up. The 9.99 was just thrown away. I needed to find a cable for dvd recorder which connects to the
dvd drive and all they were telling me was stuff I had already done
and places I had already looked but still no part , part no. NO
HELP THanks for nothing...
Posted on Aug 27, 2008
Hallo, I'm new here, I hope someone can help me with my problem. I have a Panasonic DMR-HS2 DVD recorder, and I've had no problems yet, till recently. I had programmed several TV programs. W
It might well have crashed!
I suggest you unplug or turn off the power to the unit and leave it off for a while to see if it corrects itself when you power up again.
Keep a look out for any codes in the display when it powers up. Was there a disc in the drive when you shut it down? That might be contributing to the problem if there is.
If the hard drive has failed it still might be possible to remove it and recover the contents, before fitting a new one. There are the same ones you buy for home PC's afterall.
Mar 08, 2017 | Panasonic DMR-HS2 DVD Recorder
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
Broken cable
Here is one of the biggest parts dealer
If you cannot identify the part number contact them calling
(800) 648 - 6657
(708) 946 - 9500
Aug 26, 2008 | Televison & Video
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
