Question about HP DeskJet 932c InkJet Printer
HP 932 RED LIGHT STAYS ON
THE SECOND RED LIGHT FROM THE GREEN ONE STAYS ON BLINKING AND WILL NOT PRINT. WHAT CAN I DO?
THANKS.
  • 2 more comments
  • dvsteppe Aug 29, 2008
    My red light ( 2nd from the green light) is flashing constantly and I can't get anything to print.....
  • PWAF Sep 13, 2008
    I have the same problem. I have changed the black ink cartridge (I print in black all the time), but the printer still does not work.
  • cags657 Sep 30, 2008
    The second red light from the green light stays on and I cannot get anything to print.
  • Anonymous Jan 15, 2009
    exact same problem..
    i changed the black ink cartridge but the link is still blinking and i cannot print anything
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Posted on Oct 14, 2008
Same problem here
Posted on Sep 19, 2008
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Ps3 stopped suddenly working and red light blinking push the on/off button the light stops blinking and stays fix red push again turns green few second then red blinking again any idea what may have...
Hi Andrea.
What your experiencing is the the well known "PS3 Red/Green Light of death" which generally means a hardware failure or overheating. If it's overheating (2 Red lights) then it will automatically shut down after a while but from what your saying it's not overheating.
If you have it in warranty you have to send it to Microsoft and they will send it back usually 3-4 weeks or take it to a reputable gaming console repair shop (this will cost money).
But first check that your AV cable is properly plugged in (in this case all four RED lights are bleeping). If you're using an HDMI connection forget about this step.
So if you don't have a warranty then it will cost you about $150.
Another thing you can do is follow a guide and repair all of the errors with the PS3 including your problem. Click here for more information.
May 19, 2011 | Sony Playstation 3 (PS3) Console
I have a blinking red and green light on my c60 epson printer that stays blinking. It wont print. What can I do?
you need to reset wast pad counter by using adjustment program. you can download a program "SSC service uitilities"
Dec 27, 2009 | Epson Stylus C60 InkJet Printer
Red light stays on and will not print
there is a second piece of paper stuck in the machine.
open the back flap, look at the diagram, and pull out a piece of hardware
behind this hardware, all crumpled up, not visible, is a jammed piece of paper.
Jul 11, 2008 | Brother HL-5240 Laser Printer
HP DeskJet 932c InkJet Printer Logo
844 people viewed this question
Seeker5211
Seeker5211
