Question about Ovens
Maytag stove MER5750BAW
All Digital displays work and buttons, but the all burners and oven stopped working
  • 135 Answers
SOURCE: Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Posted on Jul 30, 2008
  • 116 Answers
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
If the oven was working before then
1. Power is gone from the unit - loose connector or neutral wire ( or ground wire depending on wiring system being used)
2. The power supply transformer (or transistor) on control board is busted. This is especially true if there was power problems in the apartment- power going on and off frequently. Check the wiring and see what comes up. Hope that helps
Regards
Posted on Sep 04, 2008
  • 1214 Answers
SOURCE: Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Posted on Feb 16, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
EllaWatson25
  • 725 Answers
SOURCE: I too have an Admiral stove and the top 4 burners
If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number, we can attempt to diagnose this problem for you.
We look forward to getting you cooking again.
Posted on Nov 08, 2009
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
Maytag electric stove w/ovenMODEL #-MER5750BAW I'm geetting an F1 error code after the oven heats up. Can I find out what this coad means?
F1 code is a defective electronic control(clock). There is no reset or quick fix. The EOC must be replaced.
Dec 25, 2009 | Maytag Ovens
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
117 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
