Question about RCA P52926 52" Rear Projection Television
Power light comes on, then nothing
After about a year +, the power from remote and from TV does nothing. Occasionally, the light will come on, it sounds like it is going to power up, but then there is a low hiss, almost like a CD player makes when it is broken. No smoke, no fire, no sound, no picture. Then the light goes out by itself.
  • veekay69 Aug 30, 2008
    I am having the same issue with the same model.
    Genius:
  • 2,920 Answers
Power supply is shot
Posted on Sep 02, 2008
WHY does the power light come on but no picture or response to remote ?
If the TV dies not come on then you have a power board failure. You need to remove the board and check for bad capacitors. You can replace them yourself if you are good with soldering, otherwise get service to fix this issue.
Jul 13, 2014 | Sanyo Televison & Video
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
I have a 2004 Chevy Silverado. Occasionally when I turn the key to start it nothing happens. I have power, all lights come on. There are no noises or anything. If I use the remote starter, it works.
sounds like the ignition control switch has gone bad. all light will come one but if you turn to start and nothing happen but works with remote starter then the first thing to get checked is the ignition control switch.
Nov 11, 2013 | 2004 Chevrolet Silverado 2500HD
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
I have a Panasonic 32 inch HDTV. TV worked great until one day tried to turn on and nothing. It acts like it has no electrical power. We have tried plugging into different outlets with no luck. The red...
One simple solution may be to replace the power cable or the power strip that the TV is plugged in to. If you cannot get any power to the TV even after this step, it is most likely a motherboard or some sort of circuitry issue. Make sure you are using the physical buttons on the TV when trying to turn the TV on; leave the remote out of the equation. If it still does not come on, your TV may be far gone. HDTVs have a lifespan these days of anywhere between 3-5 years for plasma, 5-7 years for LCD, and the new LED tvs are supposed to last anywhere between 7-10 years.
Feb 28, 2011 | Panasonic Televison & Video
TV will not come on by remote or power button
There is a problem inside the set. There is nothing that will lock the set up. I would start with the power supply. Thanks
Oct 28, 2009 | RCA 20F514TD 20" TV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Sharp LC32AV22u does not turn on
press the on button on the remote and see it with the help of mobile phone's camera. If u did'nt see a light coming out of the remote, then your remote is faulty.And if u see light then your tv sensor is faulty.
cheers
Sep 10, 2008 | Sony RM-V310 Remote Control
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
