Question about Casio Cassiopeia E-125 Pocket PC
Harddisk Would it be possible to control (read) a hard disk from a casio e125? with that i mean a harddisk out of a desktop. I'd like to take a 20GB HD full of MP3's in my car and play this music by using media player on the casio. Please advise. Rudi
    Master:
  • 551 Answers
Theoretically it is possible. You would have to get/rig up a cf to ide connector. Pinouts are available on the net. Rig your hard disk in an enclosure such that your HDD from the PC is well buffered against shocks during your car ride. Personally though I feel you are asking for trouble with an extremely high probability of head crash & rendering your HDD totally unusable.
Posted on Sep 06, 2005
I can not find Harddisk in Toshiba Satellite A35-S1592 PC Notebook,Pls help me now I can not open data in Harddisk.Thank so much for read.
You can purchase an external hard disk casing to plug in your hard disk and extract the data on another PC.
Mar 08, 2011 | Toshiba Satellite A35-S1592 Notebook
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Aug 04, 2010 | Compaq Presario 5000 PC Desktop
How to replace the hard drive in a Sony VGC-LT25E computer? I am not sure how to remove the back cover to do this
Remove the Screws placed at the back of the Cabinet & Remove the hard disk connections. Unscrew the harddisk screws and remove it. After that place the new harddisk in place of old harddisk. After that place the connections of mohterboard as they were before..
May 06, 2010 | Sony VGC-LT25E Desktops. 500 GB hard...
How do i fix the cannot find the correct hard disk problem in my PS3
Test you console with another harddisk to see if it detects the harddisk.
Also try a low level format on the harddisk with a pc so to ensure that there
is nothing left on the harddisk, when reinserted in the ps3, the ps3 needs
to fomat the harddisk, quick fomat will be enoug.
If the original harddisk is still not detected, then your harddisk is defective
and needs to be replaced, if the console also doen't detect the new harddisk then your ps3 needs to return to Sony because the sata controller on the motherboard of your ps3 is defective.
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Nov 17, 2009 | EliteGroup K7S5A Pro Motherboard
I am usubg 845 gvrs motherboard now I want to installed extra internal harddisk what will be ideal harddisk and size
The size of the hard disk depends upon what type of programs you are running and the amount of data you need to store.
Programs that create large amount of data are audio and video files.
The tpye of hard drive depends on what type of disk controller you have, it could be IDE or SATA disk controller, you need to check your computer's hard disk controller.
The average hard disk capacity is 160 Gb to 180 Gb and goes up to 1 Tb, but the largest capacity drive your cmputer can support will depend upon the BIOS.
Jul 21, 2009 | Intel Computers & Internet
1 logical harddisk degraded, RAID Poweredge
Revert back to original configuration of hdd in your RAID setup. Boot to SCIS BIOS and double check functionality of hard drives. The error is probably telling you that Disk1 is degraded because disk 0 is failing and you removed the wrong hard drive.
Jul 11, 2009 | Dell Computers & Internet
OPERATION SYSTEM NOT FOUND
You must of handled to motherboard incorrectly and possibly fried the SATA/PATA controller, usually found on the North or south bridge. My friend had the same problem, leaving the motherboard useless. IF this is a laptop your screwed (I.E. motherboard is junk). If this is a desktop you can either replace the motherboard OR you can buy a SATA/PATA card that inserts into the PCI/PCI-E slot to create a place to plug your hard drive in. Hope that helps.
Jun 04, 2009 | Fujitsu Siemens Computers & Internet
MOBILE HARDISK IS 40 GB.HARDDISK PROBLEM IS DATA CAN NOT COPY FROM MOBILE HARDDISK OR PASTE IN MOBILE HARDDISK. HARDDISK SERIEL NO:-Q2KXOPE. HARDISK MANUFACTURING DATE:- OCT-06.
Maybe your hard disk is locked. Or kindly look at the properties of the Hard Disk see if the Read Only option is unchecked.
thanks
Mar 22, 2009 | Computers & Internet
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
47 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
